side moldings
Old Aug 27, 2009 | 12:28 PM
Mike Mike17's Avatar
Question side moldings
i wanna take of my side molding but im worried theres gunna be a line where they were i have a silver 03. Also for the people who have taken them off howd you do it?
Old Aug 27, 2009 | 12:33 PM
DRG35MIA's Avatar
There was thread on this same subject a few days ago in the same section.
https://g35driver.com/forums/g35-cou...you-think.html
and here is the link to take it off.
https://g35driver.com/forums/body-in...s-g-coupe.html
Old Aug 27, 2009 | 01:29 PM
gary c's Avatar
Welcome to Driver Mike....=)
Removal is relatively easy since we live in a warm climate, and it's removed just like what we refer to as DEBADGING. It just takes a little longer due to the size of the molding. You'll need fishing line, GooGone, ScratchX and some quality wax upon completion. Do NOT use anything else on your painted surface other than what I listed above, some members recommendations are flat scary. (alchol..rubbing compound) Once the molding is removed saturate heavily the glue with GooGone and a rag but don't rub hard cause you'll scratch the paint....take your time. With the glue removed use an applicator pad and rub the area with ScratchX to remove any shadows. Now you can apply wax....should look like new! Invest in some micro-polish rags that makes the job results better. (used for wax removal) "GOOD LUCK!"
Gary
wonderizm
Sep 24, 2015 03:09 AM
paolojericho11
Aug 27, 2015 10:21 PM
linedr89
Aug 17, 2015 05:11 PM
