The last two mornings while driving to work the DSC OFF, Brake, and SLIP light will turn on randomly. Usually about 5 mins into the drive. The Brake light has turned off both times after another 2 mins, but the other 2 remain on till I stop the car. Is this common or uncommon? Anyone see this issue before?
Ron
Ron
There's probably 100 threads on this if you search.
https://g35driver.com/forums/brakes-...light-all.html
https://g35driver.com/forums/g35-sed...vdc+abs+lights
https://g35driver.com/forums/dfw-g35...vdc+abs+lights
https://g35driver.com/forums/g-spot/...vdc+abs+lights
https://g35driver.com/forums/v36-gen...vdc+abs+lights
https://g35driver.com/forums/drivetr...vdc+abs+lights
https://g35driver.com/forums/g35-cou...vdc+abs+lights
https://g35driver.com/forums/brakes-...vdc+abs+lights
https://g35driver.com/forums/florida...vdc+abs+lights
Thanks Calvin I did a quick search but VDC OFF BRAKE AND SLIP didn't get me a result. I'll dig through these.
If it is low brake fluid, your brake pads could be pretty worn and in need of replacement soon
