2nd>3rd Gear Thump in AT Coupe
Old Aug 20, 2004 | 05:31 PM
sm16's Avatar
Well I now have 1250 miles on my coupe and in the last 100 miles or so I keep feeling a thump when shifting from 2nd gear to 3rd gear in manual mode. It's not a gear shifting thump, but something else that doesn't feel right.
Has anyone else experienced this? Is it normal?
Thanks!
2004.5 G35c Ivory Pearl/Graphite 5AT
Premium/18inch Wheel Pkg/Front Lip/Splash Guards/NAV/Viper 850 Alarm System
50% Madico Charcool Tint all around
Z-Tube, and Grounding Kit on the way....
Old Aug 20, 2004 | 05:52 PM
GR8TG35's Avatar
Re: 2nd>3rd Gear Thump in AT Coupe
I have over 15,000 miles on my car and had no experience with the 2nd to 3rd shift in manual mode...
If I drive my car at highway speed for 30 minutes or more, and come to a full stop and shift into reverse, I almost always get a "thunk" sound from the rear u joint/rear end. Its almost like the trans is over compensating and really shifts hard.....if I idle for a minute, it will not do that....just a little something I noticed since ownership of the car......
04 cpe IP/willow/5at/prem/18's/JDM clear corners/Piaa's/MTEC H4 Super White fog/highs
Old Aug 20, 2004 | 08:05 PM
EZZ's Avatar
EZZ
hahahaha. I said the exact same thing you did, just an hour ago to my dealer. I've complained about this other times in this forum but nobody truly answered what the hell the hump was. I have had it for the last 1000 miles. Its only in manumatic and its annoying. I will keep you informed.
04 Coupe Auto/DG/Prem/Nav/Perf
Old Aug 20, 2004 | 08:16 PM
Msedanman's Avatar
O.F. Administrator
I would guess that you are 'short shifting'. In other words, you're shifting too soon.
At moderate to wide open throttle, shift closer to redline(at least 5 to 6K rpm) and my guess is that your "thump" will disappear.
To prove the theory, leave the tranny in 'D' and let the TCU decide on the shift points. My guess is that they will be butter smooth.
Let us know how it goes and G/L. [img]/w3timages/icons/smile.gif[/img]
C.
<font color=red>GSM</font color=red>
<font color=black>Silverstone Coupe</font color=black>
Old Aug 20, 2004 | 08:33 PM
sm16's Avatar
Yeah, when I'm in D it shifts perfectly fine. It's just when I'm in manual mode shifting up from 2nd to 3rd is when I get this "problem". It's weird cause if I was shifting the same way in the other gears, this "problem" doesn't occur.
EZZ - let me know what your dealer says. I have to bring my car in next weekend for an oil change and I'm going to mention it to them.
Maybe I should just reset the ECU, that might possibly help.
Gsedanman - I will try what you said and see how it works out.
Thanks!
Old Aug 20, 2004 | 10:50 PM
lorinserbenz's Avatar
gsedanman is right, I experience the "thump" at lower rpms on occasion in manumatic mode... shifting close to redline no thump. IN full auto its perfect....
Old Aug 21, 2004 | 02:08 PM
KAHBOOM's Avatar
lift the throttle slightly and the thump will not occur during part throtle acceleration.
2003.5 G35C 5AT
Premium Package
Tire/Wheel Package
K&N Filter, Z-Tube, EGK
Old Aug 21, 2004 | 07:41 PM
ozracer01's Avatar
I've noticed this thumping too, but only when i'm giving about...hmm...75% throttle and shifting under 3k. If you shift above 3k rpms, the thump isn't there. In D mode its non existent.
Old Aug 21, 2004 | 08:28 PM
EZZ's Avatar
EZZ
I tried getting a test drive at the dealer but could not due to the lack of technicians on a weekend. I have however complained previously and the dealer tested out everything and said that everything was normal. If our trannies break, hopefully they will increase the powertrain warranty. I'm thinking the gears are in good condition because D mode works great. Perhaps manual mode isn't too good for our cars?
Old Aug 22, 2004 | 12:15 AM
sm16's Avatar
Well I tried it tonight, and if I shift around 5K-6K the thump does not occur, but anything below that I feel it. In auto, I never feel it. It's tough to shift around 6K every time....if I keep doing that, I'll need to get gas every 180 miles.
I'm assuming my dealer will say everything is normal, so I'm just going to keep driving as usual, and if something breaks I'll just have the dealer replace in under warranty.
Thanks for the feedback guys!
arora_g35
Apr 16, 2026 02:52 PM
Blakearold
Aug 19, 2015 10:20 AM
ddietz97
Jul 26, 2015 06:16 PM
Lsantana757
Jul 20, 2015 09:08 AM
G35OUTLAW6MT
Jul 13, 2015 02:26 PM
