G35 coupe front strut bar?!
Old Aug 23, 2004 | 11:08 PM
fatboygarage's Avatar
Does anyone know which company make the front strut bar for the G35 coupe. Would the 350z strut bar fit the g35 coupe?? I really want to get one. I wanna get one, please someone help me!! Thanx.
Old Aug 23, 2004 | 11:40 PM
tgalvez's Avatar
Re: G35 coupe front strut bar?!
most people go with either the hotckings or stillen.
I just go mine installed (hotckings) and they are worth every penny. The car feel much more responsive,
Old Aug 24, 2004 | 12:30 AM
GRider35c's Avatar
they dont make a front strut tower bar for the G35... its not possible.
tgalvez is thinking the anti-sway bars...
04 / Black Obsidian / Graphite Leather / aero / splash / prem / perf / cc / 22%tint
z-tube / k&n drop-in / Eclipse AudioVideoNavigation 2454 / side-blinker mod
Old Aug 26, 2004 | 01:03 AM
Godzilla35's Avatar
is it not possible because of hood clearance issues? or other technnical problems?
Old Aug 26, 2004 | 01:24 AM
Aznteazer's Avatar
are u talking about hotchkis sways?
Old Aug 26, 2004 | 02:17 AM
xswl0931's Avatar
It's not possible because the G35 doesn't have the necessary mounts.
Old Aug 26, 2004 | 08:06 AM
SixFive's Avatar
Crawford was going to do a strut bar for the G but he nixxed it. He said the AC lines are routed differently than the Z and they get in the way of the bracket that needs to be added. He said to re-route the ac lines is WAY pricey for a 200 buck mod.
2003.5 DP 5AT Sedan
14.2 @ 97.18
Z-Tube
K&N Drop In & Airbox Mod
10 Wire Hyper-Ground
Crawford Plenum (V4)
UR Crank Pulley
Hotchkis Sways (M/M)
Polk EX-3500 Tweeters/Shock Sensor/H-Liner
Old Aug 26, 2004 | 12:03 PM
GRider35c's Avatar
i believe the G does have the necessary mounts, but its a problem of hood clearance...
Old Aug 26, 2004 | 04:00 PM
Gsedan35's Avatar
As mentioned above, the G35 is not blessed with the required special welded on mounting tabs that they gave the 350Z, so you cannot begine to mount a strut tower bar even if you wanted too. One could step into their local Nissan parts department and order the 350Z body panels that have the mounts, they cost $219 per side so you'd order 2. Then slice the mounts off and weld them too your G. But you have other things in the way to deal with besides all that.
Here's a detailed study I did on the subject so hopefully people would use the search feature and know the question had already been answered. But I do keep the link handly just the same.
https://g35driver.com/forums/showthr...ar&Main=179768
"All that's necessary for the forces of evil to win in the world is for enough good men to do nothing.”
Edmund Burke
G35 6mt
vstypicals
Jul 20, 2015 10:55 PM
cyrus32
Jul 18, 2015 06:22 PM
attarday
Jul 15, 2015 04:03 PM
djreinx
Jul 13, 2015 05:04 PM
