VDC & SLIP light on
Old Dec 7, 2009 | 10:35 PM
jgarcia's Avatar
VDC & SLIP light on
I got to my car after work and drove home ... Noticed that the "VDC OFF" light and "SLIP" light stayed on and didn't come off. My traction control was clearly not working (i was able to fish tail).
i get home and leave again, then the lights come off, any reason this might have happened? My VDC is working properly now and i will say that my brake light was on as well. I was low on brake fluid, and after addin gbrake fluid, the light has come off.
Could the brake light/sensor for low brake fluid have something to do with it as well? Maybe it's the cold weather? ... any ideas?
thanks.
Old Dec 7, 2009 | 10:40 PM
Maciuniu's Avatar
low brake fluid...check your brake wear also.
Old Dec 7, 2009 | 10:41 PM
drtran's Avatar
I had the same problem a few days ago when it was really cold. Like you I just refilled the fluid and it went away. Not sure but it seems like everyone has ran into this problem at some point.
Old Dec 7, 2009 | 10:44 PM
jgarcia's Avatar
Cool ... I thought it might jut be that. I appreciate the input.
Old Dec 7, 2009 | 10:55 PM
jebus2006G35's Avatar
same problem bro. brake light all lights were always on. i was on MIN- on the brake fluid. I put it on MAX and done. no morez =)
Old Dec 7, 2009 | 10:57 PM
jgarcia's Avatar
Good to hear. thanks
Old Dec 8, 2009 | 01:12 AM
EndlessWaltz112's Avatar
jebus, check your brakes though. they might be getting low as well. its usually a sign that you'll need brakes soon.
Old Dec 8, 2009 | 10:19 AM
jgarcia's Avatar
thanks, i will check them.
Old Feb 16, 2010 | 08:27 AM
ITSAGTHING's Avatar
Sweet, I was just playing in the snow and these three lights came on. with 130,000 on my car, this kinda scared me. Thought it would be the very first issue I had with my G. Nothing that a few ounces of DOT 3 didnt fix!!!
Old Feb 16, 2010 | 08:33 AM
Glive35's Avatar
Brake wear, just had this problem myself!
Mry
Mar 3, 2023 01:03 AM
SiMpLyMoDiFiEd
The FX-Spot
Dec 2, 2021 04:35 PM
JermaineSanders
Aug 18, 2015 08:57 PM
Wayne9011
Aug 17, 2015 01:24 AM
Wayne9011
Jul 27, 2015 11:25 AM
