drive belt
Old Jan 5, 2010 | 12:16 PM
whoisthis's Avatar
drive belt
A quick question. can a slight change of the drive belt can cause the alternator to go bad? The car to have less power?
Does the belt have to run in a perfect straight line??
thx
Old Jan 5, 2010 | 02:57 PM
toyotabike's Avatar
Only one correct way to put on the belt. As long as all the ribs of the belt is on the pulleys you should be fine with correct tention of course.
Old Jan 5, 2010 | 09:03 PM
whoisthis's Avatar
this is really weird... i did not take out the belt although i attempted to, the car is running weak at idle. It idled REALLy weak like it's gonna shut off for the first day.. it's not that bad now although it's not as strong as b4. i hope it's fine
Old Jan 5, 2010 | 11:27 PM
toyotabike's Avatar
Clean out the throttle body a bit. Probably the idle air passage is dirty which will cause it to idle low. NOTHING to do with the belt.
Old Jan 5, 2010 | 11:45 PM
whoisthis's Avatar
phew...that takes away my burden
Old Jan 6, 2010 | 12:03 AM
Neu Era's Avatar
drivebelts should be oem fit, unless you have aftermarket pulleys and or have taken out powersteering and ac.
Old Jan 6, 2010 | 01:41 AM
whoisthis's Avatar
i haven't touched those things lol
Old Jan 6, 2010 | 06:35 AM
Blue Dream's Avatar
I drove ttrank's car solo
Try an ECU reset.
Old Jan 6, 2010 | 11:52 AM
V35 Skyline GT's Avatar
6MT Coupe
Clean the MAF too.
Calvin
Southern California
12
Oct 15, 2015 04:21 PM
Wayne9011
Aug 17, 2015 01:24 AM
D1dphresh
Aug 7, 2015 06:10 PM
wuppiedog
Aug 7, 2015 11:16 AM
Wayne9011
Jul 27, 2015 11:25 AM
