04 > 03?
Old Sep 2, 2004 | 12:47 PM
ck600sl's Avatar
04 > 03?
Hey guys. I bought my 03.5 in May, 2003. Recently it was totalled in an accident, but I was having so many problems with it at that time like 1) fuel tank sending unit, 2) grease streaks, 3) pop/tick from windows, 4) shifting drivers seat, 5) bad chipping paint, 5) vdc/slip light coming on, etc.
Anyway, I'm close to getting an 04. Getting a great deal on it with the 04 closeouts and was wondering if all of these problems I was having with my 03 were fixed in the 04s. They were a constant source of stress for me and would hate to go through that all over again.
Anybody with an 04 have any feedback?
Old Sep 2, 2004 | 01:24 PM
roneski's Avatar
Devil's Advocate
Re: 04 > 03?
All I can say is that I haven't had any of those problems.
Ivory Coupe 5AT
Z tube, K&N drop in.
Fujitsubo Y pipe...
Old Sep 2, 2004 | 01:37 PM
EZZ's Avatar
EZZ
Re: 04 > 03?
The 04s are more reliable for sure. Many of the TSBs were fixed. I'd get the 05s as those are probably even better.
04 Coupe Auto/DG/Prem/Nav/Perf
Old Sep 2, 2004 | 02:00 PM
P_Diddy's Avatar
Re: 04 > 03?
I'd wait for the 05. Have you seen the thread w/ the video on whether to buy 04's vs. 05's?
Basically, unless you are going to keep your car a long time, you are better off buying the 05 because the 04's already have 1 yr of depreciation on them, which is more than the value of the discounts they will give you on the lot.
2004 6MT DG/G Coupe | Premium | Aero Kit | ClearBra | See profile for pix
Old Sep 2, 2004 | 02:38 PM
Thor20's Avatar
Re: 04 > 03?
What type of deal are you getting? I am interested in purchasing an 04 as well. Sorry did not mean to hijack your thread.
Old Sep 3, 2004 | 01:26 PM
patrickwong's Avatar
Re: 04 > 03?
i haven't had any of the problems either. However, i think infiniti's paint is thinner cuz i get some nasty road chips.
Old Sep 3, 2004 | 01:42 PM
No1Better's Avatar
Re: 04 > 03?
"5) vdc/slip light coming on, etc."
unless you're going straight down the freeway and this happens then it's a problem. however, mine does it all the time when i take corners and gun it when it should come on and let you know that the car is slipping...
APC is my weapon of choice.
APC reeks of great taste.
APC is the greatest aftermarket company in the world!
Old Sep 3, 2004 | 03:05 PM
ck600sl's Avatar
Re: 04 > 03?
Quote: unless you're going straight down the freeway and this happens then it's a problem. however, mine does it all the time when i take corners and gun it when it should come on and let you know that the car is slipping...
sorry...actually it the slip, vdc off, and brake light that come on and stay on.
Old Sep 4, 2004 | 07:31 AM
SixFive's Avatar
Re: 04 > 03?
there is a TSB for that - that was common I thought and 20 minites to replace the brake light sensor..?
2003.5 DP 5AT Sedan
14.2 @ 97.18
Z-Tube
K&N Drop In & Airbox Mod
10 Wire Hyper-Ground
Crawford Plenum (V4)
UR Crank Pulley
Hotchkis Sways (M/M)
Polk EX-3500 Tweeters/Shock Sensor/H-Liner
