Clutch Pedal sticking
Old Aug 5, 2010 | 10:52 AM
  #76
monteitis's Avatar
After a bunch of headaches and switching out of cylinders, the cause of this problem for me was the clutch line being clogged/restricted. Easy fix, try changing it first. Make sure you wrap it in heat-wrap as well.
Old Aug 27, 2010 | 09:41 PM
  #77
Sals G35 Coupe's Avatar
I have been experiencing this in my 05 Coupe. I changed the fluid twice and it is still happening. Any suggestions on brand to replace my master and slave cylinder?
Old Aug 27, 2010 | 11:12 PM
  #78
tnmt_donkey's Avatar
I just had the same problem today. Uphill, waited at stop sign.
But meanwhile I could smell something like burnt aluminum.
I was so afraid that I needed to replace the flywheel and clutch set, becuase I am saving money for the turbo setup..
it will work ok for me if $75 to change master cylinder.
I will call dealer on monday anyway...
Old Aug 30, 2010 | 12:59 PM
  #79
305G35's Avatar
Originally Posted by SiouxFallsG35
If this is happening in stop and go traffic or after long idling (basically heat situations), here's the thread you need
https://g35driver.com/forums/drivetr...l-problem.html
Read that and watch the video in that post (http://rangeracceleration.com/Clutch_Care.html).
I fixed my Maxima (70k miles) and G (20k miles) limp pedal problem for about $10 and a trip to walmart. Syringe out old fluid, put in DOT4 synthetic (much better heat tolerance than OEM DOT3), problem solved. I thought this was the most ridiculous thing I'd ever heard until I read about so many people fixing this problem with this incredibly simple method. I didn't do any of the 2 person bleeding that some people do. Just did it myself with several syringe sessions over a few weeks. Ran solid all summer long with no more worrying about stop and go traffic. I theorize that many who've had their master or slave cylinder replaced were really only fixed for awhile because of having new fluid in the process. That obviously doesn't encompass everyone, but it's my theory.
thanks
Old Aug 30, 2010 | 04:57 PM
  #80
ewuzh's Avatar
Originally Posted by ewuzh
This started happening to me a few months ago (6MT sedan). Exact same problem as everyone else, clutch pedal gets stuck near the top and I have to pull the pedal up with my foot for the last 20% of the way.
First time I took it to dealer, they "lubed" the pedal. Didn't fix anything.
Went back again the second time and they replaced the slave cylinder. Problem went away for about 5000 miles, then came back in full force.
Third time, the dealer replaced the master cylinder. Now it doesn't stick every time, but occasionally it will still stick. From what I've observed, the problem doesn't seem to be temperature dependent.
After reading about others' experiences here, I went out and picked up a bottle of DOT4 brake fluid to flush out the system. The fluid in the reservoir already looks clear and fresh, but it can't hurt to flush again.
Update: Replaced/cycled clutch fluid with DOT4. Sticking went away for a few weeks but just started to come back once in a while. Changing the fluid has been the most cost effective improvement by far.
Old Aug 31, 2010 | 01:01 AM
  #81
alexbass311's Avatar
Had the same problem as all you guys. I've also found that changing the fluid fixes almost all the problems. I just used the ranger method and got out as much as possible and replaced with the DOT 4 and haven't had many problems since. A few times it was a little sticky, but only in really high heat and a lot of stop and go. I will probably try to completely flush it to fix this.
Old Aug 31, 2010 | 10:59 AM
  #82
1sweetg35's Avatar
I had this same problem a couple of years ago. Pedal would stop a few inches short and it also squeeked. It was driving me crazy so I got under there and slaped some litium grease on everything down there and it instantly fixed my problem. I've since put 40k miles on the car and it hasn't occured again even once. Everybody needs to try the litium grease before anything else.
Old Sep 9, 2010 | 04:07 PM
  #83
mtrappo's Avatar
T3K V35 should know what he is talking about and to back it up ... i had my whole clutch, flywheel, all bearings, slave and Master cylinder replaced. I had all the fluids replaced, bleed and the problem still exists. I am going to do what he (T3K V35) said and replace the assist spring and bushing then clean and lube everything.
And mine only does it when it's hot too.
Old Aug 23, 2012 | 03:50 AM
  #84
bythabay's Avatar
So I have been having a similar problem. Here's the scoop:
2006 G35 Coupe 6MT was complaining about hydraulic problems (pedal sticking).
Needed a new clutch, so I threw in a new OEM flywheel and an NSK1000 complete clutch kit. Also installed a new transmission cover, pin ball, pin ball washer, input shaft seal, and cover gasket. The 4 bolts at the bottom of the cover are one time use only!
Got everything back together, bolted up the slave - low and behold a sticking pedal - I immediately attributed this to the customer's complaint and shrugged it off as "not a big deal, I'll just bleed it when I'm done with everything."
Once I got it all back together, I started bleeding it.. for HOURS on end - no improvement. I threw a clutch master and slave kit (oem) at it as a last ditch effort, tried every bleeding technique I could think of and nothing seemed to help.
At this point I assumed there was an air bubble I just wasn't going to get out and that it was someone else's turn to waste hours of their time on this.
Customer picked up the car and drove away.. a few hours later it occurred to me - the clutch fork holder spring INSIDE THE TRANSMISSION was installed upside down... this is what was preventing all the air from getting out of the system during bleeding.
Moral of the story is: if you get a clutch job done and they can't bleed it after, check the clutch fork holder spring! I've attached a photo of what it looks like installed incorrectly. You want the ears facing upwards, not downwards where they can interfere with the movement of the fork.
Old Sep 17, 2013 | 07:05 PM
  #85
iDShaDoW's Avatar
Sorry to bump an old thread but I've been reading anything and everything I can find and was hoping you all could provide some advice.
And sorry about the long post. I tend to make long posts instead of posting a bunch of follow-ups with more questions.
Anyhow...
My brother's '05 has had this problem probably since the car hit 35k miles and he never got it taken care of. Fast forward to 55k miles and now the clutch is slipping.
1. I'm looking at the factory OEM clutch kit for ~$345 shipped from a dealership vs Exedy OEM NSK1000 for ~$220 shipped from Exedy. Opinions?
2. A co-worker's mechanic friend said he can swap the clutch out for $450 in labor. Good/Decent price?
3. Should I consider getting the master/slave cylinders (or just the slave cylinder), cable, and fluid (DOT4) replaced, and pedal greased by the guy all at the same time while he's down there changing the clutch out? What would be considered a reasonable charge in labor to do so?
4. Is #3 something learnable/doable on your own? Seems like bleeding the clutch fluid and greasing the pedal assembly would be simple enough after watching some videos and reading a little. The slave cylinder seems straightforward as well but I'm not sure if it'd be a pain to reach while under the hood.
I see the slave cylinder here; says it's for 03-05 but the part number doesn't seem to correct for 05s (should it still work fine?). Good price as well?
http://www.nissanraceshop.com/produc...305-30620cd00a
Don't see a master cylinder on their site. Any recommendations on where I can find an OEM master cylinder at a good price or would you all say that the master cylinder likely has nothing to do with the clutch pedal sticking?
Thanks for any detailed help/information.
mbe32
Nov 13, 2015 11:09 PM
AL8782
Oct 3, 2015 10:26 AM
dcsbh1
Oct 1, 2015 03:15 PM
Hogbone
Sep 28, 2015 06:44 PM
jbmw002
Sep 10, 2015 12:54 AM
