passenger window
passenger window
so yesterday my passenger window decided not to roll up. didnt hit any bumps or nothing like that just wouldnt roll up!!
what should i look for that is wrong? it could be the fuse or motor i think. how do i check if it is the fuse and how do i remove the door panel??
First, I'm new here.. but any moment now they are going to tell you to search, and call you a noob... SO. Hop to it
edit:
The first ones free:
https://g35driver.com/forums/body-in...l-removal.html
edit:
Try opening the motor like the link in the second post should show...Most of the time what happens is the brushes inside the motor get clogged up and are no longer moving freely. That can save you some time on replacing the motor.
cant be window lock because driver side button should be able bring it up
and i did try to open it last night but i was drilling this screw off and it got all flat and im not sure on how to get it off.
tabris- thanks for the link
What are you saying here? Did you strip a screw? If so, which one?
most likely its the motor.
If youre in a pinch and absolutely need to get the window up, turn your car on or put the ignition to ACC. Then open the pass door, hold the window up button and while still holding the button, shut the door. The window will go up. This is a last resort type thing. i suggest getting the motor replaced ASAP.
Im actually replacing mine tonight or tomorrow since it finally took a sh*t on me this past weekend. I cleaned the metal buildup out of mine about 2 months ago but its not a permanent fix.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
BradMD_96
Oct 6, 2015 09:31 AM
Learned Hand
Oct 1, 2015 09:02 AM
