tires
Old 09-17-2004, 02:37 AM
rchun08's Avatar
tires
do you all think 235/40/18 would fit all around instead of staggered 245. I know the front rims are 18x8 and the back rims are 18x8.5 would this cause problems with fitting 235's all around let me know. thanks
Old 09-17-2004, 09:20 AM
def35's Avatar
Re: tires
I don't fitment would be a problem, the diameter might be however. Overtime your odometer will read incorrectly.
Old 09-17-2004, 04:17 PM
CKwik's Avatar
Re: tires
According to everything I've read(Brochure, manual, magazines), the wheels are the same size. I've heard the offsets may be different but I haven't seen any written documentation of that.
Old 09-17-2004, 04:54 PM
gidontknow's Avatar
Re: tires
I think your VDC would get screwed up without the stagger. You might want to investigate that first. There have been server posts about the problem in the past.
Old 09-20-2004, 11:47 AM
myfastg's Avatar
Re: tires
you can always test it in a parking lot
Old 09-20-2004, 11:57 AM
Pratik's Avatar
Moderator
Re: tires
I thought they were all 18x8 right?
D. Graphite/Graphite | Premium | Splash | Clears | Pedals | 35% TINT | Z-Tube | 4080 Stealthbox - JL 10w3 | Escort 8500 | PIAA's
Old 09-20-2004, 12:28 PM
P_Diddy's Avatar
Re: tires
The main issue is the overall rolling diameter of the wheel/tire.
The VDC, ABS, and other electronics monitor the rotation rate. At a given speed, the smaller fronts are rotating faster than the bigger rear tires. If you put on bigger ones, it may screw these systems up.
You could possibly go w/ a 245/40-18 (vs. stock 45-series tire) to decrease the diameter.
2004 6MT DG/G Coupe | Premium | Aero Kit | ClearBra | See profile for pix
Old 09-20-2004, 02:48 PM
NYCXLR8's Avatar
Re: tires
Just wanted to throw in with the others who have noted this already. The stock 18's are all the same size. I posted this info a month or so ago (a clip from one of the technical manual page). If you need it check my old posts.
2004 G35c AT/Prm Pkg/Sport Pkg/Aero Kit/Clear Sides/Pedal Kit/Tint/Z-Tube/K&N Drop-in/Smoked Rear Overlays/Gialla Grill
Old 09-20-2004, 02:50 PM
NYCXLR8's Avatar
Re: tires
LOL, I went down six posts and my old message was there.
https://g35driver.com/forums/showfla...t=1#Post347094
TwinTurboZ
19 Inch
09-26-2015 06:11 PM
JG_G35
19 Inch
14
09-19-2015 09:04 PM
bananax
Wheels & Tires CDN
09-10-2015 06:14 PM
philthethrilloh
09-09-2015 01:25 AM
socaldavid
09-05-2015 04:35 AM
Quick Reply: tires
