Weird "banging" noise coming from rear passenger side when going over bumps
Old Apr 18, 2010 | 02:50 AM
Jaysanity's Avatar
I currently have placed my new 19" aftermarket wheels on and I noticed that when i go over certain dips/bumps I hear a loud banging/scraping noise that comes from the rear passenger side. My car isn't lowered either. Also, if i go over some bumps ie.train tracks at high/low speeds the noise disappears.
I was wondering if anyone could help me with this since i cringe everytime i go over a bump and wait for that sound. I would like to get some insight before I go to the stealership!! Thanks in advance guys.
Old Apr 18, 2010 | 03:03 AM
elayman's Avatar
could be fenders rubbing on your tires. even if you aren't lowered, if you go over a huge bump it can still hit. Are your wheels very aggressive?
Old Apr 18, 2010 | 05:39 AM
seymore4's Avatar
m56
Is it possible that your girlfriend is tied up in the trunk?
Old Apr 18, 2010 | 03:21 PM
silver g's Avatar
Are you sure your lugs are tight?
Old Apr 18, 2010 | 03:35 PM
WILLIE BEANS's Avatar
dead hookers need to be tied down ..
sorry i have no idea ..
Old Apr 18, 2010 | 09:16 PM
Jaysanity's Avatar
My wheels are aggressive but not out of the ordinary from other G's out there...front 245/35/19 and the rear 275/35/19
I also don't think its the rubbing since its only happening on one side (rear passenger side)...unless something else is wrong in in that area...my uncle who is a mechanic says it could be hitting the the pipe that leads to the gas....not sure what that is called exactly.
Old Apr 18, 2010 | 09:19 PM
Jaysanity's Avatar
yeah they are all tight torqued to 90
Old Apr 18, 2010 | 09:21 PM
Jairen's Avatar
Have you checked the bushings in the differential? Check for a black streak on the differential cover.
Jaysanity's Avatar
haha...funny guy
i think that's more of a thump than a scraping/banging sound
Old Apr 18, 2010 | 09:23 PM
Jaysanity's Avatar
i have no idea what that even is...but i will definitely find out.
Old May 22, 2010 | 02:15 AM
carsoon's Avatar
I am having the same problem as well. I keep getting these weird noisy banging noises going over bumps in the back right corner. I recently changed my tires from winter back to my summers and noticed that one of my lug nuts fell out and the others were loose! I torqued them to spec and all the other tires were fine so I thought the noise was related to a loose tire. But now that I have the summers on, and double checked the torque, it's making the same noise... Any help???
Old May 22, 2010 | 08:04 AM
Jaysanity's Avatar
going to wait to get it checked out at the dealership soon...is it more of a scraping noise too? mine sounds like a scraping noise depending on how fast or how big the bump/dip is...also no sound is made going over speed bumps or train tracks
Old May 22, 2010 | 08:27 AM
officerdbag's Avatar
scraping nosie should be rubbing.. What are the offsets of your wheels?
Old May 22, 2010 | 08:28 AM
herrschaft's Avatar
For the scraping noise, did you to check to see if any of the plastic **** underneath the car or fender linings were loose?
Old May 22, 2010 | 03:48 PM
Jaysanity's Avatar
+20 in the back (9.5), +15 in the front (8.5)
checked that...didn't seem to find anything
