Front Compression Rod
Old Apr 22, 2010 | 10:12 PM
hnamgoon's Avatar
I have just purchased 04' G35 Coupe 6MT (50K Km) in January and recently, I have been noticing knocking and clicking sound from driver side front suspension. The noise only starts on low speed or when I am breaking. I have been reading the Fourms about noise from Front Compression Rod, but I am 100% sure if bad bushing form FCR makes knocking or clicking sound ?
Old Apr 23, 2010 | 11:10 AM
G35fromPA's Avatar
It certainly can. The CR bushings are known to go bad and I just had mine replaced at 31K miles.
Old Apr 24, 2010 | 02:41 PM
snowrider13's Avatar
I was told by the stealer that I need it replace, but I dont hear any noise.
CR Bushing a DIY?
Old Apr 26, 2010 | 10:53 AM
hnamgoon's Avatar
Changing any bushing is not an easy DYI. You need a press to take it out and in and most of the bushings are very hard to get it out. Futhermore, I understad that in order to take CR out, you need to also remove the sub frame as well, not a easy job. So I would recommend to purchase entire CR and spend couple of hundred dollars to get them professionally installed.
Old Apr 26, 2010 | 10:58 AM
hnamgoon's Avatar
I found out the source of the clicking sound. It was my stupid mistake. When I installed Hawk break pad for me Brembo front breaks, I foregot to put back the metal shimmies. Oops. We are still working on the knocking sound. My shop can not seem to find any visible damages to the front compression rod or and bushings.
Old Apr 28, 2010 | 03:02 PM
elrooko's Avatar
I just changed mine. Unless you remove the compression rod and look at the top of the bushing, it will be hard to see damage. From the bottom of the bushing when it was on the car it looked fine but when I removed it from the frame I could see that the top of bushing was all ripped.
Old Apr 28, 2010 | 05:59 PM
Procharger G's Avatar
I'm having the same problem. How much $ should I be expecting to spend to get this fixed?
Old Apr 28, 2010 | 08:00 PM
elrooko's Avatar
Depends on how handy you are. Buy the parts from Tony@Riverside and you can attempt to DIY. It actually isn't that hard so long as the bushing isn't coroaded to the bolt. Mine was and I had to give up and go to the dealer to get them to change it. You can also a local independant to do it as it really isn't that hard. I paid about 180 a rod from Tony and the dealer charged me an hour labour per side. I've heard of dealers trying to charge upwards of 1K for this.
If you buy the parts yourself from Tony plan on $360 plus 2 hours of labour from a garage to install both sides.
Old Apr 28, 2010 | 08:55 PM
jutn35's Avatar
G35 Coupe
https://g35driver.com/forums/g35-cou...-clunking.html
i got a steal at the dealers, $350 for everything
MyfistYourFace
Aug 8, 2015 11:58 AM
kinetek
Aug 3, 2015 04:25 PM
keithk831
Steering & Suspension
Aug 2, 2015 09:50 PM
itschuckster
Jul 25, 2015 08:07 AM
LoSt180
Jul 15, 2015 08:31 AM
