Weirdest thing happened today
Old May 11, 2010 | 01:02 PM
GoDaddy's Avatar
I started my engine and then the radio didn't work, so i click on mode on the wheel than the AC started out of no where.
Now I can't turn off the AC, can't control the temperature. The radio won't turn on. Nothing works on the dash.
Does someone knows what happening?
I got an 03 coupe.
Fuse?
Old May 11, 2010 | 01:20 PM
joedaddy1's Avatar
was your CD player broken?
you need a new CD player..
Old May 11, 2010 | 01:22 PM
GoDaddy's Avatar
yeah the cd is broken. Actually it can play one cd only.
That can cause all that ? The AC/Heat, temperatures, etc to not function?
Old May 11, 2010 | 01:29 PM
VxLyf3's Avatar
check the fuse box
Old May 11, 2010 | 01:44 PM
GoDaddy's Avatar
How do I detect a dead fuse?
Old May 11, 2010 | 01:52 PM
1blualti's Avatar
i was told before that the a/c and radio are integrated by a nissan tech. thats why getting a double din dash kit is so expensive for our cars /c you have to buy the a/c control part...
so its possible...
Old May 11, 2010 | 02:19 PM
Integi2a00's Avatar
there are multiple threads on this but 1blulti is right.... either get it fix which expensive or go get a JDM double in or a metra double buy a cd player and your good to go.. i got a metra kit buttons are not great but i'm satisfied for the price...
Old May 11, 2010 | 02:50 PM
Mo's Tre' 5's Avatar
ive had this problem for a year now...LOL!!! i gotta get it fixed...a/c always on and the radio finally gave out...i dont wanna spend $300 on a plastic fking dd kit...
Old May 11, 2010 | 05:47 PM
That1GuyG35's Avatar
Im not to sure about this so you will have to check with your dealer but when my OEM CD Changer was messing up the service guy told me that Infiniti has some sort of program that will let you get an OEM changer/radio from them installed for around $500.00 (lucky for me it was still under warranty) but this is due to the high cost of the OEM changer if you were to have to buy a new one from the parts department. So at least they are trying to help which is nice.
Considering that the radio does control so much stuff, not just the sound system, this could be a way to go. I have the bose system in mine, so I thought at first it was just overpriced and I could replace it with a double din, but nooooooooooooo they had to go integrating stuff into it. Or, you could find a working one on ebay and follow one of the DIY's on here to replace it.
Hope that helps!
Old May 11, 2010 | 06:32 PM
superchargedg's Avatar
Time to get another factory radio or go after market.
Old May 11, 2010 | 07:08 PM
joedaddy1's Avatar
i just switched out my cd player for like $180 from ebay.. and it's been working fine since.. no need to do that expensive upgrade, etc..
Old May 11, 2010 | 09:01 PM
vipers's Avatar
I've had issues with my CD player since I bought the car. Take a ride to the stealership.
Jussaku
Aug 4, 2015 12:45 PM
ClwMike
Jul 23, 2015 12:55 PM
