NEED HELP(OIL and Gas)
Old May 22, 2010 | 04:39 PM
MyGfaster1's Avatar
i went to the nissan dealership today to see if i needed a oil change cause it was atleast 1k til oil change but it seemed on the dipstick it was very low so i guess my G was burning oil? but then again i dont have white smoke coming from the exhaust either so the rings shouldnt be bad. The reason i think it burned more oil is that just a week ago i just started using 91 octane. before i was using 89 and was just wondering could that be the reason why it went through oil faster because i was using a lower octane grade of gas? not sure on this but hopefully its that. PLEASE does anyone know what i could be. thanks
Old May 22, 2010 | 05:00 PM
tEh d0ct0r's Avatar
Why were you using 89 when it clearly states by the gas cap to only use premium? Its not a suggestion.
Old May 22, 2010 | 05:10 PM
MyGfaster1's Avatar
because i thought shell gas went unleaded(87) premium(89) then vpower was just above um it was a humen mistake but would that be a reason why my oil was getting low? cause i was using a lower grade of gas?
Old May 22, 2010 | 05:15 PM
tEh d0ct0r's Avatar
I honestly don't know the answer to that question. Hopefully some of the more technically inclined guys will help you out. Just FYI, premium is typically between 91 and 93 octane.
Old May 22, 2010 | 05:19 PM
MyGfaster1's Avatar
yea i know that know i feel bad on how i was giving my G 89 for sooo long but yea hopfully someone can help me out on this question thank you anyways
Old May 24, 2010 | 06:17 PM
shocker611's Avatar
i did the exact same thing :/ and am having oil consumption issues as well.. hopefully it will all be because of our dumbasses using the wrong gas haha
Old May 24, 2010 | 09:37 PM
gck's Avatar
gck
check out my threats!!
Old May 24, 2010 | 11:28 PM
gary c's Avatar
Just because your now using the octane gas you should have used all along has no relationship to OC. Keep an eye on your oil, if you start using more than a quart every 1K miles take it on for the OC test. No warranty, start looking for a new motor....
Gary
Old May 25, 2010 | 08:17 AM
gck's Avatar
gck
i mainly use 93 octane but many times i jump from 89 to 93 to the other lowest one..and ive had no problems at all!.....?
Old May 25, 2010 | 02:20 PM
MyGfaster1's Avatar
ok yea i understand that it might not have anything to do with that, but i see no oil leaks under my car and also my rings arent burning because white smoke or any smoke at that isnt coming from exhaust, so im going to see how it does and im thinking that from using lower octane wasnt cutting it and when it wasnt it was burning more oil so the car wont sieze up or anything like that. all G's are different, but i am putting v-power in now so i hope it runs better and just poured 5 quarts in this saturday and have been checking oil for past few days and also reving exhaust to see if any smoke, oil is where it should be and no smoke.
sales@czp
Suspension-Vendor
26
Nov 6, 2017 03:04 PM
g.spot
May 9, 2016 10:54 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
alessandro
Oct 8, 2015 09:29 AM
vamarris
Sep 26, 2015 12:56 PM
