while my Gs sitting in my garage...
Old Sep 28, 2004 | 04:09 AM
g_thirtyfive's Avatar
for 2 more months (cause license is suspended i thought i might as well do sumthin with the car. im considering painting the grill black. i know that this probably has been discussed but again nuthing comes up with search. i was just wondering wat kinda spray paint should i be buying??
TIA
Old Sep 28, 2004 | 08:57 AM
MyGUnit's Avatar
Re: while my Gs sitting in my garage...
how fast were u going?
Mitch
2004 G35C 6MT
DG/G
Prem.Aero.Nav
Clear Corners
Old Sep 28, 2004 | 09:22 AM
azcougarman's Avatar
If you are going to use spray paint out of a can, I would recommend a brand called SEM. They make bumper and trim paint. Better automotive paint stores should carry it and it will run you about $10 per can. Make sure you rough up the grill with a scotch brite pad prior to the primer coat to give the primer something to stick too. Remember, the cheaper the paint, the more often you will have to repaint it.
<P ID="edit"><FONT class="small"><EM>Edited by azcougarman on 09/28/04 06:24 AM.</EM></FONT></P>
Old Sep 28, 2004 | 09:32 AM
malx's Avatar
Bumper and trim paint? How good is this actual paint? Does it withstand heat also?
Thanks - Joey Avino
Old Sep 28, 2004 | 11:21 AM
Joey, its as good a paint as you will find in a can. I have used it over the years with good success. The paint is heat tolerant and would be fine on the grill--but not your BBQ grill!. I would not use it on any engine components.
Old Sep 28, 2004 | 03:29 PM
well im in canada, and tickets just added up...the last one was 93 in a 50 zone at a end of a highway (the cop was SO hidden i cant even remember where i saw him)...cops are sneaky these days
azcougarman, wat do u mean by roughing up the grill?
Old Sep 28, 2004 | 04:35 PM
BigRon's Avatar
You know, a punch to the gut, sock it in the nose, take it's lunch money... ...that type of thing.
Seriously, he just means making the smooth surface a little more rough so the primer sticks to it better. Use one of those green cleaning pads (ScotchBrite pad) and rub it over every bit as much of the grille surface as possible. You want to it to be covered in fine scratches so the primer can cling to the surface better. With the ScotchBrite pad, the scratches will be shallow enough that the primer and paint will cover them smoothly.
'05 IP(or ?) 6MT... ...Never too soon to think about modifications!!
Old Sep 28, 2004 | 05:39 PM
lol aite that makes sense thx for the help bigron
Dallsinghjr1
Sep 17, 2023 11:25 AM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
DRG35R
Jan 31, 2016 07:14 AM
Jay123
Sep 28, 2015 08:42 PM
doakley92
Sep 25, 2015 12:58 PM
