has anyone ever fix the p1274 & p1283??
Old Jun 7, 2010 | 05:51 PM
RHINO04's Avatar
was wondering if anyone has fix the p1274 & p1283 codes from popping up. please help
Old Jun 8, 2010 | 01:20 AM
SKYY-35's Avatar
try this. Good luck.
http://www.my350z.com/forum/forced-i...1283-p302.html
Old Jun 8, 2010 | 01:33 AM
RHINO04's Avatar
Hey sky did you have the same problem?
Old Jun 8, 2010 | 02:25 AM
Dr. Ephil's Avatar
Uprev does the trick, the ecu can be programmed to ignore the codes. Though they're Nissan codes they're generic in nature to the problem that's causing the CEL to trip. The extensive diagnostics I had done on the codes showed bank 6 was running lean so to compensate 10% more fuel was fed to that bank. No matter what the guys at the speedshop tried nothing worked until Uprev. By coincidence this is the same bank that suffers from the leaking valve cover seal. I wonder if this has something to do with it?
Dallsinghjr1
Sep 17, 2023 11:25 AM
KruZZe
Feb 27, 2023 05:04 PM
Marlin84
Apr 1, 2020 12:52 PM
KallDay86
Jan 8, 2016 12:42 AM
NyCrAzY
Oct 1, 2015 09:19 AM
