can somebody explain what this f***ing sound is??!!!!
Old Jun 8, 2010 | 05:27 PM
amarouni's Avatar
Angry can somebody explain what this f***ing sound is??!!!!
please help what the hell is going on with our G's???!!!!
the common problem all over this site is the cold startup sound can somebody explain what is this sound????
that's what is happening with me:
usually in morning or after parking the car for more than 6 hours and when i start it up i can hear some noise coming from the engine like "tec,tec..."????!!!!!!!!!!
and i have searched this site and have found that a lot of people here having the same problem and i have found a thread that shows a guy who had this problem, he get his car to the dealership and after making checking on the car the dealership decides that he need to REPLACE the ENGINE!!!!!!????? and since he is still on warranty the dealership changes his engine and got him a new one.
but we the people that are out of warranty wtf we are going to do!!!????????
please are u all guys having this problem or just few
i can see on this site that is a common problem here, so if it is SHAME on infiniti how can they build this type of engine.
this is the link for the guy who replaced his engine:
https://g35driver.com/forums/engine-...upe-video.html
i'm a 2003 g35 coupe owner.
Old Jun 8, 2010 | 05:58 PM
SoulGlo's Avatar
voice means noise?
Old Jun 8, 2010 | 05:59 PM
NachoCheese's Avatar
There's a midget in his engine compartment yelling at him every time he starts the engine.
Old Jun 8, 2010 | 06:10 PM
jibberjabbers's Avatar
You motor is Fked... Get a compression test.
Old Jun 8, 2010 | 06:54 PM
VQ Johnny's Avatar
It's the timing chain rattling, something to do with the tensioner. I had the same noise at start up with my old maxima (2002) and the same for my G.
Old Jun 8, 2010 | 07:27 PM
dias724's Avatar
i have the same noise, i dont worry about it. I know its notting major because it only happens in the morning so it must have something to do with oil flow... the guy u posted about got his engine replaced not because of the noise but for oil consumption.. he took it in for the noise but they found something else. And yes it might be the Chain Rattling after an oil change it becomes louder then it goes back to normal.
Old Jun 9, 2010 | 06:26 AM
LMG_35C's Avatar
If the ticking goes away within seconds of start up there is probably not too much to worry about. If it takes minutes then I'd become a bit more concerned.
What kind of oil and oil filter are you using, and how many miles? Some filters either have defective anti-drainback valves or none at all, or the valve is poor quality and can't stop 0W from getting back into the pan.
If the noise is oil-related (cylinder heads being starved) overnight should not be an issue unless the filter valve is bad or missing. Nissan does have a TSB about adding oil to upper cylinder after prolonged storage or an engine build.
I use PureOne 14610 and Castrol Synthetic / Edge 5W-30 and haven't experienced this noise except after weeks of sitting idle (I don't drive the car in winter). In that case I've learned to add a small amount (1/4 qt) of oil, and to prime the system using a couple of false starts (turn motor without starting) to get the oil pump charged.
Old Jun 9, 2010 | 09:35 AM
amarouni's Avatar
Originally Posted by SoulGlo
voice means noise?
yes it is a noise* not voice sorry.
Old Jun 9, 2010 | 09:48 AM
amarouni's Avatar
yes noise is just for 1 or 2 secs, u mean that i shouldn't worry about it, is it a normal issue to my G?
i'm using 5w-30 and i change it after each 3500miles.
and i'll be changing it in the next week and also i'll change the filter.
i hope it to be a normal issue and nothin is wrong here
thanks for u info
Old Jun 9, 2010 | 01:48 PM
Everyone thought that his engine noise was "normal".. Turned out, he needed a new engine....
Best thing to do is have a professional look at it. Especially if it's still under warranty.
Old Jun 9, 2010 | 07:22 PM
LMG_35C's Avatar
I wouldn't disagree, especially if it's under warranty but that noise in the video is far beyond a ticking noise. Sounds like valve chatter (timing chain, cams, valve seat issues) to me and is definately not right. No wonder they replaced the engine, the diagnosis and repair would exceed that cost.
Old Jun 9, 2010 | 07:58 PM
yogi41's Avatar
Is the ticking sound very loud? If it sounds like someone is banging a metal rod against your engine you should have someone take a look at it. If its a ticking sound that you can't hear in the cabin then it might just be noisy injectors.
Dallsinghjr1
Sep 17, 2023 11:25 AM
Marlin84
Apr 1, 2020 12:52 PM
Video Share
Jan 31, 2017 04:00 PM
atomevolution
Engine - Exhaust
Oct 12, 2015 01:00 PM
dcsbh1
Oct 1, 2015 03:15 PM
