Cross drilled Rotors with brembos
Old Aug 4, 2010 | 10:55 PM
gcode's Avatar
Question Cross drilled Rotors with brembos
Can I buy the same rotors as all other G's or do the brembros require something different, I just need something that's not as ugly the stock rusted ones I have. Not to concerned about brands and performance, just price
Old Aug 5, 2010 | 12:51 AM
TheG35Dude's Avatar
The brembo rotors are much bigger than the stock rims, they are special and more expensive.
Old Aug 5, 2010 | 03:27 AM
Revo's Avatar
If your rotors were bigger than your rims you could never mount your rims...
The Brembo rotors are specific as far as I know. They are typically a little larger and have a greater contact surface.
Old Aug 5, 2010 | 07:14 AM
grovefromnh's Avatar
You can get aftermarket rotors for your Brembo calipers. Just be sure to specify that you have them. I use the dimpled/slotted rotors from EBC.
Old Aug 10, 2010 | 01:50 AM
InfinitG's Avatar
I got some Brembo Sport Drilled rotors from tirerack, they were much cheaper than the OEM Brembo rotors.
Old Aug 10, 2010 | 06:06 PM
G35fromPA's Avatar
You can a set of excellent aftermarket rotors for the Brembo setup - Centric Premium rotor blanks. You can also get them heat-treated for a little more durability. I am running them now on my Brembo '04.5 and they feel exactly like OEM (I am also running OEM pads) at a fraction of the cost of OEM.
Many places carry them, like tirerack.com and rockauto.com. Fronts are ~$60-70/rotor.
Old Aug 10, 2010 | 08:32 PM
gary c's Avatar
GCode, you can find anything you want by checking with our MARKETPLACE under vendor brakes. Prices are far better than the outside companys some members listed. DBA makes rotors for the Brembo system and that's high quality stuff at a reasonable price.
Gary
Old Aug 11, 2010 | 06:12 PM
G35fromPA's Avatar
Gary, DBA's are definitely nice, but they are pretty pricey compared to Centric rotors, which are the basis for Stoptech stuff. OP stated he wasn't concerned about brand or performance, just price. And, FYI, our vendors are good, but Rockauto is as dirt cheap as I've found on the internet.
Old Aug 11, 2010 | 06:27 PM
Neu Era's Avatar
Brembo requires bigger rotors. Hence the Bigger calipers.
Old Aug 13, 2010 | 11:51 AM
ZeRo G35's Avatar
Good thread... i am also interested in upgrading my rotors to the slotted or drilled. I also am on stock Brembo Calipers... any issues with upgrading to brembo rotors and run on brembo calipers?
Centric Premium rotor blanks: are these slotted or drilled?
Brembo Sport Drilled rotors: cost on these?
Old Aug 14, 2010 | 12:38 AM
dr.g35's Avatar
If you're wanting just rotors:
http://www.z1motorsports.com/350_g35...oducts_id=2123
or if you're wanting to do just a nice upgrade:
http://www.z1motorsports.com/350_g35...oducts_id=2241
Old Aug 14, 2010 | 05:16 PM
walshtj's Avatar
Gary
+1 I was looking at those the other night.
Marlin84
Apr 1, 2020 12:52 PM
Picture Share
Feb 4, 2018 12:41 PM
nanobotking
Oct 8, 2015 08:40 AM
dcsbh1
Oct 1, 2015 03:15 PM
