looking to reuild my engine to handle 400hp, what internals is it gonna take?
Old Aug 6, 2010 | 07:58 AM
johnsonp's Avatar
i want s/c eventually but dont wanna have to get a new motor in a yr or so. i know im gonna need pistons, rods, gaskets but not sure what else?
Old Aug 6, 2010 | 08:35 AM
Tricky-Ricky's Avatar
I know Cosworth do a lot of stuff for the VQ35DE, like pistons, rods, heads, plenum, not sure about the crank, but i have heard that they can run up to flywheel 400BHP on std internals, although personally i wouldn't want to go any more than 350-360, as they don't seem to be a particularly strong motor.
Old Aug 6, 2010 | 09:16 AM
Swivel's Avatar
Moderator
Not sure why you think that. IMO any engine that will tolerate near-doubling of its output on stock internals is plenty strong.
Old Aug 6, 2010 | 09:22 AM
walshtj's Avatar
OP I think you should search and learn alot before attempting a project like this, if not you are going to waste your time and money...
Old Aug 6, 2010 | 09:23 AM
Swivel's Avatar
Moderator
And not make two threads practically the same in one section.
Old Aug 6, 2010 | 09:26 AM
GreenGoblin's Avatar
The goblin resurrection
stock internals will hold 400, so anything else will be plenty.
walshtj's Avatar
Hahaha that also. Why do all noobs do this?
Old Aug 6, 2010 | 10:05 AM
herrschaft's Avatar
If isn't an issue then just swap to a built long-block
Old Aug 6, 2010 | 11:14 AM
The VQ35DE was built to a spec and price, and unlike some older designs was not an over engineered and inherently strong engine unlike the 2JZGTE for example which is quite happy at 5-600BHP on std internals.
The VQ does not have pistons or rods that will take FI, please feel free to show me an example of a FI VQ engine that is running over 400BHP on STD internals, let alone double.
Old Aug 6, 2010 | 03:32 PM
herrschaft's Avatar
400BHP
^To me that means crank HP, not WHP, and there are a lot of G's with stock blocks running that much.
https://g35driver.com/forums/forced-...-you-push.html
Old Aug 6, 2010 | 03:51 PM
IrockAG35's Avatar
Ohio G Club moderator
just do basics..unless ur going TT, SC's are only good for about 450-500whp on 11-13psi...id recommend cp pistons 8 :1 :1,eagle rods,arp headstuds,550cc injectors,stage1 fuel return..as for gastkets, youll need an FI gastket kit..id also recommend getting exhaust,HFC's,and maybe a performance manifold such as the kinetix..it wont be cheap but if u go FI its just a matter of time b4 it has to be done
Old Aug 6, 2010 | 04:43 PM
It means crank BHP to me too, not the over inflated WBHP figures i see bandied about, had a quick look at the link, i would like to see just what some of the claims to high WBHP on stock blocks actually look like when connected to a proper engine dyno
I have seen very few dynos that read with any real accuracy, and many are calibrated to make customers happy, also as BHP is calculated from torque, a lot of those figures have no chance of being accurate.
jsimonk
Dec 22, 2023 03:49 PM
Drifter2090
Dec 26, 2015 12:10 AM
Team STILLEN
Aug 10, 2015 08:17 PM
THMotorsports
Midwestern
Jul 22, 2015 10:27 AM
