lowering problem
Old Aug 9, 2010 | 02:55 PM
r.drifter's Avatar
lowering problem
hi guys im about to put on the tein h tect lowering spring on my coupe. its for G35 coupe H tech not 350z h tech. my question is do I need a camber kit or i could still use my stock one?
Old Aug 9, 2010 | 03:18 PM
gary c's Avatar
The Tein G35 H-Techs won't lower your car much so after you install the springs have it aligned. Then you can tell how far off OE alignment specs you are. Chances are very good you'll need adjustable a-arms (F) and camber arms/toe bolts (R) which you can buy here on DRIVER under our Marketplace....vendor suspension. It's much better to buy the adjusters now than new tires once a year....
Gary
Old Aug 9, 2010 | 03:22 PM
LightsOut's Avatar
SIETESG
with that minor of a drop, you wont need an aftermarket alignment kit.
yes, your front camber will be slightly off but not by much. Toe can be corrected.
Rears both toe and camber can be adjusted.
you'll be with in oem specs.
Old Aug 9, 2010 | 03:38 PM
saywat?'s Avatar
ima say no need kit
Old Aug 9, 2010 | 05:57 PM
mistuhlayzee's Avatar
what about s techs
Old Aug 9, 2010 | 06:00 PM
herrschaft's Avatar
Originally Posted by mistuhlayzee
what about s techs
The S-techs will wear out your tires, as well as your struts (depending on how you drive). You will want camber kits with those.
Old Aug 9, 2010 | 06:02 PM
haha thanks for the info, was planning on getting lowering springsas well, but wasnt too sure about the camber kits.
Old Aug 9, 2010 | 06:40 PM
ThickG's Avatar
So, if I drop on S-techs and get camber kits, would I still need to worry about my struts wearing out prematurely or would the camber kit take care of it?
Old Aug 9, 2010 | 06:53 PM
herrschaft's Avatar
They will ultimately shorten the life of the struts but the contributing factor is how you drive. I do a lot of spirited driving and my struts were blown at 45K miles, 9-11 months after I've lowered the car. The camber kits simply help fix camber issues and have nothing to do with the struts.
Under normal driving conditions the OEM struts should last a little while but expect to replace them within a few years.
Old Aug 9, 2010 | 07:18 PM
walshtj's Avatar
Yeah for s-techs I would def get chamber kits. For h I wouldn't.
Old Aug 9, 2010 | 08:34 PM
ThickG's Avatar
Would it be prudent to simply get new struts when I lower my car or can this wait until the OEM ones are blown?
Old Aug 9, 2010 | 08:54 PM
herrschaft's Avatar
I believe you should get as much use out of your current struts as possible. Yours may last longer then mine...
Old Aug 9, 2010 | 09:45 PM
gary c's Avatar
I can only go by my experience with the Tein 350Z H-Tech springs I installed. I didn't get an alignment for 2 weeks after springs were installed to let them settle. After the alignment, in about 30 days I started hearing the famous Roooooar from my front tires. Couldn't turn up my tunes high enough not to hear that damn noise. Checked my tires and got back with the tech that did my alignment. His advice was, due to the simple fact our suspension has very little adjustment and to get the suspension pieces to correct it which I did. Not all our Gs are the same but before I'd tell someone that camber/toe adjusters weren't needed I'd ask the tech doing your alignment how far off OE specs the alignment is....opinions don't mean squat if you alignment is way off and can't be adjusted....logic!
Old Aug 9, 2010 | 09:49 PM
saywat?'s Avatar
^^well the htechs for the z installed on the g will drop it lower ima guess .5 ichnes lower on the g so thats probably why u had the camber issues. but im sure u already kno that. i got tanabe nfs so im speaking from experience as well and have no camber issues
Old Aug 9, 2010 | 10:01 PM
herrschaft's Avatar
^Point taken. But 350Z H-techs lower more then G35 H-techs. And I never have met/read about anyone with G H-techs that needed a camber kit. I agree that an alignment should be done first to see the results before deciding on adjustable components. But of the G35's I've installed these springs on, not one of them had camber out of specs enough to require camber kits. Thats my experience...
erickLA
Aug 18, 2015 04:46 AM
mann1961
Aug 9, 2015 08:44 AM
chinee
Aug 8, 2015 10:11 AM
sailfish250
Jul 30, 2015 11:39 AM
