blown motor
Old Sep 11, 2010 | 04:07 AM
  #46
partyman66's Avatar
Originally Posted by 3rick35c
I dont think I would ever consider the RB just because I know we can push out more power when we Force feed our VQ's not to mention if I were to Run into a CHP officer who knows his ****...I would be SOL at the state ref when I am sitting there with a diff motor... I am sure I would pass smog...but would auto fail on the visual inspection of the engine
You can push more power reliably out of an RB than a force-fed VQ, no questions asked. Those RB's can take a lot of abuse on stock internals than a VQ35DE motor can. Just to point out the obvious... your VQ blew without forced induction.... what do you think will happen if you multiply the power by 1.5 or more times stock output?
RB would be an expensive swap though due to all the fab work involved and you never really know what you're getting when you buy a motor from overseas... plus what you mentioned about the legality of trying to run that motor in your car over here in the US.
If you're looking for an upgrade, I'd probably investigate the option of swapping in a VQ37VHR motor, although those are probably not as easy to come by and will cost a lot more. This is probably going to entail a lot of changes to the car though to support that motor.... new wiring harness, ECU, new intake setup to support dual intakes and MAF sensors, etc. I think it will bolt up to the existing tranny though and should drop right into existing engine mount points. Don't quote me on that though(I haven't actually looked into it).
Old Sep 11, 2010 | 02:09 PM
  #47
3rick35c's Avatar
Under Construction
^ +1 ^ for the information
Old Sep 11, 2010 | 03:04 PM
  #48
djamps's Avatar
I saw your sig and thought you were FI... but you're not so this definitely shouldn't have happened.
Did you regularly check your oil since the change? I hope it didn't run low. It's about the only thing I can think of that could cause this...
Old Sep 11, 2010 | 03:07 PM
  #49
djamps's Avatar
Way more trouble that it's worth. There are all kinds of fitment issues due to the dual intakes and engine bay layout. Not only that but the '04 BCM/CAN and the 37HR ECU probably won't get along very well either
I would also recommend against doing a Revup swap... the '04 ECU has no way of controlling the exhaust valve timing so it's not going to run correctly.
Old Sep 17, 2010 | 10:25 AM
  #50
XLR8_'s Avatar
any word on wat caused this cause the noise my g is makin is driving me crazy i dont know wat its is....its sounds like something is broke insided... i dunno how to describe.... oh and mine is an 04 as well and i dont want any issue lol
Old Sep 17, 2010 | 11:11 AM
  #51
partyman66's Avatar
Originally Posted by XLR8_
Damm dude sorry to hear that my enigine is making a wierd noise like if somethin broke inside... Nut only does that on may 40-50mph ???
If it only does it at 40-50 MPH, it's probably not your engine making the noise. That's probably something in the tranny or further down the drivetrain such as your differential. If it was the engine, it would make it at various speeds whenever the motor was either revved to a certain RPM(depending on what gear you are in), loaded/unloaded, or reached a certain temperature... but the motor should have no relation to vehicle speed, since all it cares about is the speed of the flywheel.... the transmission takes the power from there and converts it into vehicle speed.
Post a video of the noise if you want a significant response to your question about your cars noise, because nobody here is going to be able to tell you much of anything useful about it without more detail or a video clip.
Old Sep 17, 2010 | 05:03 PM
  #52
XLR8_'s Avatar
Ok thanks ill be posting a vid today... ^^
Old Sep 22, 2010 | 09:58 PM
  #53
3rick35c's Avatar
Under Construction
UPDATE- motor was found to be tapped in with a past turbo set up... after a minor break down of the top end of the motor we found fragments of a blown up piston and its piston rings... radiator was completely trashed due to the mix of oil and coolant after the engine blew... conclusion bad piston rings causing complete engine break down... car will be up and running by tomm... thanks to scott bush and his master tech...3 day turn around
Old Sep 23, 2010 | 03:36 AM
  #54
Shocka82's Avatar
Im glad my engine popped @ 68,100 miles because the factory motor is for 70,000! I barely made it to that deadline and the dealer says that they will putting a BRAND NEW engine in there . But even if I passed 70k, I bought an extended 3yr/36k mile warranty!
Dallsinghjr1
Sep 17, 2023 11:25 AM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
BradMD_96
Oct 6, 2015 09:31 AM
thechitoguy
Oct 1, 2015 05:25 PM
master111
Sep 25, 2015 08:32 PM
