Best Tranny and Diff fluids
Old Sep 7, 2010 | 10:40 PM
V35 Skyline GT's Avatar
6MT Coupe
Been using Amsoil in my gearbox and diff since 2006. Will never go back to over priced dealer oem stuff. Amsoil and Red Line make GL-4 for our 6mt's
Old Sep 12, 2010 | 01:12 AM
xCALiBUR05's Avatar
Is this what you're referring to?
Old Sep 12, 2010 | 05:01 AM
partyman66's Avatar
OEM Nissan MT fluid in the tranny, Amsoil in the diff.
Old Sep 12, 2010 | 05:49 AM
Jairen's Avatar
Does anybody have any oil analysis test results from sources such as Blackstone?
I'd like to see some hard evidence of the "best" fluid for our tranny's.
Lot's of good info here:
http://my350z.com/forum/engine-drive...ssion-oil.html
Old Sep 12, 2010 | 11:28 AM
partyman66's Avatar
I don't think a used oil analysis on gear oil from the tranny or diff would tell you that much, to be honest. It's not dealing with the same amount of factors that motor oil is dealing with, and if you're using synthetic, it doesn't really wear down, per say(although some cheaper ones supposedly do shear)... it just picks up metal shavings or possibly water-based contaminants if you have ever had the car in a flood or real deep-puddle/water-crossing situation.
Old Sep 20, 2010 | 04:33 PM
sfsergey's Avatar
I have the same dilemma right now about which fluid to use, I'm going with dealer stuff, I have to go there anyways to get washers and stuff so might as well get it.
Old Sep 21, 2010 | 08:33 AM
Nismofan240's Avatar
just go with whatever gives you warm fuzzies inside
Old Sep 21, 2010 | 10:34 AM
bigballer8's Avatar
^ ill try red line synthetics next time i change out my transmission fluid. Had gotten my oil change done this weekend. It wasn't too bad on the G.
Old Sep 21, 2010 | 10:19 PM
railer's Avatar
J - matic fluid for the AT tranny
Amsoil severe gear oil for the diff..
Old Sep 21, 2010 | 10:28 PM
thescreensavers's Avatar
Mr.202?
^ S-Matic
J-Matic does not exist any more.
Old Oct 21, 2010 | 10:17 AM
railer's Avatar
Originally Posted by thescreensavers
^ S-Matic
My Local dealership in Toronto is still selling J-matic fluid, wasnt there some info on 1 of the threads on this site, where master mechanics were advising against mixing the J-matic and S-matic fluid (as in wen u would do a drain and refill)...?
plus if ur car came with J-matic, they recommended u stick with J-matic.
Any info available that says otherwise...?
Old Oct 21, 2010 | 11:37 AM
Swivel's Avatar
Moderator
Yes, you can use this for the gearbox, though I've had reports that it makes shifting a bit notchy when the weather turns cool. Others have been perfectly content with it.
And SVG 75W90 for the diff.
Old Nov 20, 2010 | 12:44 AM
HYDRUS's Avatar
How many quarts of tranny fluid are needed for just a drain and fill?
Old Nov 20, 2010 | 12:52 AM
Mr.202?
Never herd of master techs advising against mixing Matic J with the S. Matic S is the replacement fluid for Matic-J its compatible.
Old Nov 20, 2010 | 07:51 PM
  #30
doeboy's Avatar
I just put in redline 75W85 GL4 in my tranny. It seems to like it better. I have Mobil1 GL5 in the rear diff
