Best Tranny and Diff fluids
Old May 1, 2011 | 08:15 PM
  #46
avinashchanagal's Avatar
The best bet for the tranny will be OEM nissan recommended.
Old May 2, 2011 | 03:58 AM
  #47
Condition's Avatar
^^ I agree
Old May 2, 2011 | 12:00 PM
  #48
BolivianFuego's Avatar
Ok, so I think I will try royal purple. Pricey..... but I love my G'.
Anyone have links or know of local stores that have the stuff in stock?
Old May 2, 2011 | 02:47 PM
  #49
LoSt180's Avatar
For the SR20 crowd, Redline MT90 is king for manual trans fluid. Since the G35 has the same GL-4 fluid requirement, then I'd stick with the Redline or OEM. I remember that the GL-5 has different additives that tear up the copper syncros.
FSM states tranny takes 3-1/8 qt. So buy accordingly. It also says to replace the gaskets in the drain and filler plugs.
For the diff, FSM states 3 pt of GL-5 (which is about 1.5 qts.)
Old May 16, 2011 | 03:27 PM
  #50
So dont use redline for the rear end?
Old May 16, 2011 | 04:08 PM
  #51
LoSt180's Avatar
While I don't really see the problem, the FSM states API GL-4 for the trans and API GL-5 (SAE 80) for the diff gear oil. Figure there's 'some' reason for the difference. Rear takes 3 pts (1.5qt) and GL5 is readily available at most auto stores, it's the GL4 that's a pain to find. I've ordered Redline MT90 from summitracing.com in the past.
Section I'm referencing is MA-10 "RECOMMENDED FLUIDS AND LUBRICANTS"
Old May 16, 2011 | 04:58 PM
  #52
For the differential....... most of the oils are good. But for transmission use only OEM Nissan.......... other more advanced oils have a tendancy to eat up the synchros in our cars(bronze synchros) ...... that what i read some where here........
Old May 17, 2011 | 09:28 AM
  #53
Originally Posted by LoSt180
While I don't really see the problem, the FSM states API GL-4 for the trans and API GL-5 (SAE 80) for the diff gear oil. Figure there's 'some' reason for the difference. Rear only take 3 pts and GL5 is readily available at most auto stores, it's the GL4 that's a pain to find. I've ordered Redline MT90 from summitracing.com in the past.
Hmmm... I tried calling Infiniti and they said they dont sell diff' fluid in little bottles. Just the big drums that the mechanics have.
What could I buy instead?
Old May 17, 2011 | 10:18 AM
  #54
For the differential, you can put in most of the brands(with limited slip, it's been long so don't quote me on this) available out here ........ i for one used the Lucas.
Old May 17, 2011 | 10:54 AM
  #55
Ok Cool. They said the same thing about the tranny fluid. They only have huge drums...
Old May 17, 2011 | 11:19 AM
  #56
V35 Skyline GT's Avatar
6MT Coupe
Originally Posted by xCALiBUR05
Is this what you're referring to?
Yes and sorry for the late response.
Originally Posted by SwivelHips
Yes, you can use this for the gearbox, though I've had reports that it makes shifting a bit notchy when the weather turns cool. Others have been perfectly content with it.
And SVG 75W90 for the diff.
I used to have to dbl clutch on OEM stuff from 1st-2nd gear until the gearbox warmed up, ridiculous. No more dbl clutching needed since using Amsoil. Still a little notchy when cold, but nothing like it was with OEM.
Old May 17, 2011 | 12:44 PM
  #57
Sweet! Just ordered each.
How hard is it to change the tranny fluid and diff?
Is there write ups? I am scared to bring it to this shop i got a quote from, because my car is so damn low lol.
Old May 17, 2011 | 02:23 PM
  #58
ozzy87's Avatar
If anyone is looking to purchase Amsoil products here is a very useful link that will let you know which product is used for which fluid and also how much of it you will need.
http://www.amsoil.com/mygarage/vehic...+L&metric=True
Old Jun 7, 2011 | 04:58 AM
  #59
07Coupe6mt's Avatar
amsoil
Old Jun 7, 2011 | 05:10 AM
  #60
faiz23's Avatar
Cheapest and best combo
6mt Tranny
AUTO
DIFF
