Drive belts replacment
Old Oct 2, 2010 | 11:29 AM
omegajimmy's Avatar
Has anyone in here have replace their drive belts? The dealership will charge me $193, the parts only cost me $50, so i was thinking of diy project. The only question i have is how do u measure how hard the belt will be? Thank you ahead. Yours alway the best!!!!!!
Jimmy
Old Oct 2, 2010 | 12:05 PM
SVTCOBRA's Avatar
Pretty ez. ALso, I got my belts at Nissan for around $32
Look for online FSM's
Old Oct 2, 2010 | 12:43 PM
surma884's Avatar
It will only cost you $30 if you order from everythingg35.com. $50 is too much.
SVTCOBRA, wassup! I'm in CLT.
Old Oct 2, 2010 | 02:09 PM
SVTCOBRA's Avatar
Neighbor!!
Oh, you know, washed the G's, worked out, now on to other chores!! Maybe go look at some G's on the lots!
Old Oct 2, 2010 | 02:13 PM
velomack's Avatar
Jimmy
There is a deflection tool you can get, most people just wing it to roughly 5mm but don't quote me on that. There it a step by step DIY out the just search.
Old Oct 2, 2010 | 03:14 PM
irishsig's Avatar
Never go to the stealership for a service.
That's where they make all their money.
I bought my belts on ebay for around $40 (nissan cert parts).
And had them installed by a local mechanic shop for another $30.
Saved myself about $130.
Just search on ebay for G35 belts.
http://cgi.ebay.com/ebaymotors/OEM-I...Q5fAccessories
Old Oct 2, 2010 | 04:57 PM
velomack's Avatar
Here is the DIY Vid.
http://www.infinitihelp.com/diy/gsed..._procedure.htm
Old Oct 2, 2010 | 06:46 PM
omegajimmy's Avatar
Thank you for all the advice guys, the only thing that i'm worry about diy is , i don't know how hard do i need to go with the tension on the belt. That was my only concern. Thank you again!!
Old Oct 2, 2010 | 07:40 PM
velomack's Avatar
Here is a good read on this
https://g35driver.com/forums/dfw-g35...yeballing.html
Old Oct 2, 2010 | 10:01 PM
surma884's Avatar
Originally Posted by SVTCOBRA
Neighbor!!
Damn, I wanted to wash my G today.
Old Oct 4, 2010 | 07:43 PM
Louisiana G35's Avatar
Juat had my car seviced the other day due to the bulletin for the air bag. They called me to the back to showed me that my belt had started cracking some. They said that it would need to be replaced. It will cost me $150 plus tax for an hours work. My car is still under warranty and I would rather have them install it even though it may cost me more. If something happened due to the belt being installed incorrectly I don't think a body shop will be able to afford another engine.
Old Oct 4, 2010 | 08:21 PM
velomack's Avatar
The hardest thing about changing your belt, is taking the million bolts of the under panel off. On a scale of 1 to 10, this is about a 2. If you ever changed oil or plugs, this should be a piece o cake.
Hasanbaloch
Feb 29, 2024 08:45 PM
Muski_G
Dec 1, 2023 11:11 AM
Wayne9011
Aug 17, 2015 01:24 AM
Wayne9011
Jul 27, 2015 11:25 AM
itschuckster
Jul 25, 2015 08:07 AM
