My window will not lower when i open my door???
Old Oct 10, 2010 | 02:56 AM
amkaluta's Avatar
Question My window will not lower when i open my door???
My car just started doing this and im not sure why. My driver side only. It will not lower that inch or so that it does when i open the door but all my controls work if i want to lower my window or pick it back up. Just when i open the door it will not lower like it should anyone can help? thanks for all help...
Old Oct 10, 2010 | 09:46 AM
trunks333's Avatar
Your window motor is failing. I have the same problem.
Old Oct 10, 2010 | 10:54 AM
the_sedan's Avatar
reset your window limit switch and see how that goes... search for the thread.
Old Oct 10, 2010 | 11:45 AM
TIRE_SMOKE96's Avatar
Dude my passenger side window did that and it would not roll back up. I had to take the door apart to manually push it up before I deployed so my wife could drive it too. I highly recommend you do not roll it back down. Take to a shop and get it fixed. Otherwise you might have to put plastic in the window! YUCK!
Old Oct 10, 2010 | 10:31 PM
amkaluta's Avatar
How do you reset it?
Old Oct 11, 2010 | 04:37 PM
amkaluta's Avatar
Is it easy to reset?
Old Oct 12, 2010 | 03:52 PM
saywat?'s Avatar
dont waste ur time reseting it jus repplace the motor or atleast get ready to so when u do the reset and nothings fixed u have the motor on hand to replace instead of breaking things apart multiple times.
Old Oct 12, 2010 | 08:38 PM
amkaluta's Avatar
well my window works great besides when i get out of the car it will not lower that half an inch or whatever its supposed to do... If it was my motor wouldnt it have trouble lowering when i push the button? also if i lower the window and try to pick it up with the 2 clicks and it goes up by its self it will get all the way up then lower like half way down for some reason but if i hold the button to pick it up once it gets to the top it stays?? hopefully its not confusing lol. PLEASE HELP!!!
Old Oct 12, 2010 | 09:02 PM
saywat?'s Avatar
oh sounds like u jus need a reset then if it still goes up and down with a push of the button all the time
Old Oct 13, 2010 | 01:30 AM
amkaluta's Avatar
Ok how do you reset it?
Old Oct 13, 2010 | 03:03 PM
amkaluta's Avatar
lol does anyone know how to?
Old Oct 13, 2010 | 03:13 PM
saywat?'s Avatar
does anyone know how to search?
Old Oct 13, 2010 | 03:20 PM
erklep's Avatar
this!
ev_g35
Interior
Aug 14, 2015 02:05 PM
JMSABO
Aug 4, 2015 11:58 AM
will091195
Jul 27, 2015 09:19 PM
mjfenix
Jul 24, 2015 05:16 PM
apintojr
Jul 23, 2015 10:52 AM
