2005 G35 window wont roll up
Old Nov 10, 2010 | 01:56 PM
richardcvan's Avatar
My 2003 G35 windows wont roll up when i insert the key in the door and turn it... it used to work but not anymore.. my windows work when i hold down the unlock keys but when i go to put it up using the key.. it doesnt roll up
Old Nov 10, 2010 | 05:08 PM
n00b's Avatar
your window motor probably died. take it in for service. it will be somewhat expensive to fix without a warranty. motors run from 100-250 dollars plus installation labor if you have someone do it
Old Nov 10, 2010 | 06:00 PM
CayakaITzTri's Avatar
Look for the DIY for replacing window motor, save money and do it yourself lol. Take about an hour, really easy.
Old Nov 10, 2010 | 09:32 PM
the windows rolls up when i put the key in ignition, just doesnt roll up when i am outside the car, stick the keys in the DOOR LOCK..
Old Nov 12, 2010 | 04:47 PM
yungreezy09's Avatar
if you cant afford the motor right away just break down the door and pull the window up and re-install the bad motor **JUST DONT LOWER THE WINDOW**. just remember you may have to reprogram the window motor so it'll lower and raise when you open and close the door. but i didnt have to reprogram mine so you may luck out, GOOD LUCK
Old Nov 14, 2010 | 03:41 AM
thomas18a's Avatar
i had the same problem 2 weeks ago. I replaced the motor and it works fine now...
If you dont mind, I can do the installation for 50
Old Nov 14, 2010 | 05:46 PM
the window rolls up and down normally.. its when i am inserting my key in the door and holding it one way... the going down works but the going up doesnt.. this is when i am outside of the car
Old Nov 14, 2010 | 06:33 PM
_RR_'s Avatar
^then i would have to say, who the hell cares???
Just roll up your windows normally, jeez...
people these days....
Old Nov 15, 2010 | 01:12 AM
i just want to have that option...
Old Nov 15, 2010 | 08:51 AM
laksjd84
Feb 28, 2026 01:58 PM
lemmy999
Jul 25, 2015 12:13 PM
apintojr
Jul 23, 2015 10:52 AM
AustinErkl
Drivetrain
Jul 18, 2015 05:44 PM
Scredeur4
Steering & Suspension
Jul 17, 2015 06:30 AM
