p0011, p1283 problem error codes, please help!
Old Nov 12, 2010 | 08:50 AM
Ronjon17's Avatar
Hello All,
Last week my CEL came on. After OBD II scan I got the following error codes:
P0011 - Intake Valve Timing Control Performance Bank 1
P1283 - 02 Sensor
I reset the ECU and have driven probably about 100 miles worth of errands (small trips no more than 10 miles at a time). The light has not come back on however I still have the following problem:
Really loud Rattling noise
Whenever I rev say past 2k rpms, when the RPM falls - it falls below normal operation (say down to 200 rpms) and the oil light flash.
Through some research I have also heard that the CAM Shaft sensor might have gone bad and will cause sprocket noise. This may be the rattling noise I am hearing.
I did an oil change recently (last month 5 qts of 5w-30 mobil 1 synthetic and new mobil 1 filter), but folk have told me to start with an oil change because I may have crud in my engine blocking the solenoid.
http://www.infinitihelp.com/diy/obd_..._infiniti.html
ANY ADVICE HERE? WHERE TO BEGIN? WHAT TO FIX? CAN THE SOLENOID BE CLEANED OR DOES IT NEED TO BE REPLACED?
Old Nov 12, 2010 | 01:25 PM
Ronjon17's Avatar
bump
Anyone?
ara777
Aug 15, 2018 04:11 AM
mike730
Jan 12, 2018 04:25 PM
Ednica87
Sep 5, 2015 02:59 AM
saskicker32
Aug 11, 2015 02:12 PM
stay_tuned
Jul 21, 2015 07:09 PM
