PLZ HELP... Car Shakes when I stop but drives normal. What can it be?
Old Dec 13, 2010 | 11:08 PM
jebus2006G35's Avatar
sorry 2 bug you guys but i been having a problem with my car for a while. I don't have the CEL on so I don't know what it is. The car drives normal. Dont feel power lost but when I stop, the car idles find but then it shakes a little then idle is normal then it shakes again. it doesnt turn off but it worries me. When i drive off its like nothing happen. I did have a code for my Cats. Code P420. I went 2 the dealer and they clear the code but I dont think thats the problem because it wasnt doing it before. Plz help. Thank u.
Old Dec 13, 2010 | 11:16 PM
TIAN's Avatar
Hold The Line
Clogged injectors? Idle to low? Tell the dealer to do a idle relearn. Do you have aftermarket cats?
Old Dec 14, 2010 | 12:28 AM
G35_Brian's Avatar
rotors?? i have the same problem but its not annoying its just a little so i havent bothered to check it out. if you find out lmk lol
Old Dec 14, 2010 | 12:47 AM
i do have FI 300 Cell high flow cats. My warranty is done. My idle is normal when I do a full stop but it drops then car shakes little then back 2 normal. can it be 02 sensor? i only had the cats for 18 months
Old Dec 14, 2010 | 12:56 AM
SDGenius's Avatar
may be a bad coil pack
Old Dec 14, 2010 | 01:14 AM
B L U E S L A T E's Avatar
Honda Accord
clean the throttle body?
Old Dec 14, 2010 | 06:48 AM
Blue Dream's Avatar
I drove ttrank's car solo
Bad gas maybe?
Old Dec 14, 2010 | 07:46 AM
4DGS's Avatar
Have you checked your oil? You could be a little a low.
Old Dec 14, 2010 | 08:57 AM
miltoda's Avatar
I'm thinking dirty throttle body as well. That's any easy thing to check before you do something more expensive.
Old Dec 14, 2010 | 10:51 PM
oil is fine bro. gas is normal. im going 2 try 2 clean the Throttle body
Old Dec 15, 2010 | 10:32 PM
Footballmania32's Avatar
^Don't lose the straw in the plenum like that one guy did hahaha
Old Dec 16, 2010 | 12:30 AM
gary c's Avatar
Originally Posted by br1ans ur daddy
rotors?? i have the same problem but its not annoying its just a little so i haven't bothered to check it out. if you find out lmk lol
If it was an issue with rotors it would only shake/vibrate while coming to a stop, not at idle stopped!
HAHAHA, I think that guy was too embarrassed to ever post on DRIVER again after admitting he lost his straw while cleaning his throttle body. His mistake was asking if it would hurt anything....
To fix the rough idle issue I'd clean the throttle body to begin. If that doesn't fix the issue take it in for service, could be a coil or plugs....kinda hard to tell from here.
Gary
Old Dec 16, 2010 | 04:14 AM
ill clean it tom. then ill let u guys know. thanks for ur help guys
Old Dec 17, 2010 | 04:49 AM
josh.irvine.6's Avatar
I had the same thing. Put your window down too, and you can hear it in the exhaust note, right? Its a weird feeling and definitely unsettling wondering if your car is going to shut off at any moment. Does your RPM drop a little bit as well?
I don't remember specifically what I did.. I think I just had a full liquid injector cleaning, then I believe I also had my idle adjusted up a bit. It went away. I'm pretty sure thats all I did. But I could be mistaken.. Good luck bud
Old Dec 17, 2010 | 07:57 AM
jwolfpk's Avatar
i have the same problem to dealer told me it was from my intake i wanna go back and get my idle adjusted
