gas tank never goes full!
Old Jan 2, 2011 | 12:57 PM
fstasfk_G's Avatar
hi guys, everytime i fill my tank from e, it never goes to f! it always goes up to around 3/4 and start to overflow.... does anyone have that problem as well?
i can never fill up to the whole entire 20gal of the tank... =[
Old Jan 2, 2011 | 01:08 PM
gary c's Avatar
There was a recall several years ago over this particular issue, I believe it has something to do with the filler neck pipe. Call Infiniti and let them know about the gas tank issues you're having. You might also ask this question at www.infinitihelp.com they seem to have all the right answers.
Gary
Old Jan 2, 2011 | 02:21 PM
atmel101's Avatar
what year 2003
Old Jan 2, 2011 | 02:27 PM
walshtj's Avatar
Mine sometimes does that at 1/2 but I can usually fix it. Def go to Infiniti for the recall though.
Old Jan 2, 2011 | 03:29 PM
Smitty50's Avatar
If its not your car, than its the gas pump. Some gas pumps are falty and will not fill up your car to a full tank
Old Jan 2, 2011 | 03:45 PM
maclovio's Avatar
I thought my car was the only one that did that
But i have found that depending on the gas pump you can fill up. It just takes a few min more. Plus i dont really fill up my car all that often.
Old Jan 2, 2011 | 04:21 PM
fstasfk_G's Avatar
yea, mine is a 2004... i guess im gona go look around to see if there was any recall on the issue... i've tried bp, qt, and several different places and they all seem to be the same... thanks guys
Old Jan 2, 2011 | 04:22 PM
fstasfk_G's Avatar
http://www.automotive.com/2004/12/in...lls/index.html
that is the link i've found, and it says fuel system recall... u guys think that could be the problem?
Old Jan 2, 2011 | 07:15 PM
gmotion04's Avatar
mine just started doing this its annoying the needle goes up and down showing i have no gas then itll go up and still have the low gas light on...and when i fill it all the way up it doesnt completely show it filled on the gauge
Old Jan 2, 2011 | 07:32 PM
jibberjabbers's Avatar
I took my car in for this back in aug 2009.
Here is what is on the invoice:
Performed ITB08-041A. Replaced fill limit vent valve cover.
Here is the PDF file for the TSB. Looks like it affects 03-08 models.
http://www.infinitig37.com/TSB/1SC29.pdf
Look at the TSB, looks like it's a biotch to do. LOL Check out the pics. They have to stick their hand into the tank and the tank has to be empty before they work on it.
Old Jan 2, 2011 | 07:34 PM
gmotion04's Avatar
jib jab were you experiencing the same things i was talking about? and were you under warranty if not how much did it cost?
Old Jan 2, 2011 | 07:37 PM
Yes, that's why I took it in. Every time I pump gas, it keeps clicking off and won't let me fill it no matter what I do. I read where some people had to turn the nozzle upside down and crap like that. I decided to take it in because my car is still under warranty.
It cost me ZERO. Since they performed the TSB, I no longer have that problem. No matter what gas station I go to. So it is not the Gas station, but the car itself.
edit, I did it on aug 2010 not 2009.
Old Jan 2, 2011 | 07:40 PM
gmotion04's Avatar
appreciate it ill call infiniti tomorrow instead of for buying the jdm dd and order this lameee
Old Jan 2, 2011 | 07:48 PM
Let us know how much they quoted you for this bs. Thanks.
Old Jan 2, 2011 | 09:28 PM
fstasfk_G's Avatar
so does my car still have to be under warranty in order to get the recall fixed?
