High pitch squeak after installing JWT popcharger/Ztube
Old Jan 17, 2011 | 08:47 PM
Cox_G35's Avatar
After installing JWT popcharger / Z tube and taking for a drive w windows down I noticed a squealing sound. It sounds like a belt squeaking but only does it from 2000-2500 rpm also when you let of the gas after heavy exceleration. I did a search but there is so much about squeaky brakes and other squeaky things. I was going to try and record it but you cant hear it do to the wind. Ive tightened all hose clamps and checked and re-checked everything. This sound is bothering the crap out of me.
Old Jan 17, 2011 | 09:04 PM
Project's Avatar
Lol it sounds like the swoosh the popcharger makes. You sure its a belt squeal?
Old Jan 17, 2011 | 09:09 PM
Cox_G35's Avatar
i can hear the "swoosh" the popcharger makes WOT. Under normal acceleration it only happens @ 2000-2500 rpm. I first thought it was a belt.
Old Jan 17, 2011 | 09:11 PM
Project's Avatar
It also does it on the low end just not so Wham in your face. Almost sounds like a metallic whistle. If you go in a tunnel you can really here it. I used to get the do you have a turbo on there line all the time.
Old Jan 17, 2011 | 09:31 PM
Cox_G35's Avatar
Ive read on hear to disconnect the battery to reset the ECU. How would that help?
Old Jan 17, 2011 | 10:33 PM
gary c's Avatar
Remove the negative side of your battery, take it all off and reinstall making sure every connection is tight with zero leaks....take your time. Then put the battery back togeather and give her a test drive. Still might be one of your belts worn or cracked. (one more thing to check)
Gary
Old Jan 20, 2011 | 05:02 PM
Cox_G35's Avatar
OK. Have taken negative cable off battery and unhooked the whole set up and then re installed everything making sure to tighten everything. Still after everything I hear that squicking noise. I even took the time to make sure all the belts were fine and not dry rotted. If I dont find out what the crap this is I'm taking it off and selling it.
Old Jan 20, 2011 | 08:34 PM
caketech's Avatar
that's a normal noise
at first i had no idea what it was but i realized it's from the pop charger and i can only hear it with my windows down and when i'm driving. ie my passengers think i'm crazy.
but the battery reset is to "reset" the ecu which is supposed to help your car get more gains from the intake but eventually the car learns it.
but the squeal is normal from the intake, i mean given it wasn't there before the install.
Old Jan 21, 2011 | 06:15 PM
G35SedanGrn's Avatar
Same here, just installed a ztube & took off my "power duct" (Power duct is for a little while till i get tired of it so ill put it back) and i have a high pitched squeak and its anoying me 2, i havnt reset my ECU yet...
Old Jan 21, 2011 | 06:18 PM
kennymo's Avatar
noise is completely normal. my fujita does the same thing.
Old Jan 21, 2011 | 06:26 PM
N@eem's Avatar
mine does it in the winter days, its annoying sounds like a beat up 4 banger. but it goes away after 5 seconds. i dont hear it on summer or spring days
Old Jan 21, 2011 | 06:28 PM
N@eem's Avatar
maybe its too much cold air lol
Old Jan 21, 2011 | 11:47 PM
i reset my ecu and it sounds much better
11bEMT
May 27, 2022 03:13 PM
snic09
Nov 8, 2017 01:46 PM
Wayne9011
Aug 17, 2015 01:24 AM
Wayne9011
Jul 27, 2015 11:25 AM
