RPM fluctuation after air filter replacement
Old Feb 8, 2011 | 10:41 AM
tomykas's Avatar
hi. yesterday i changed my noname ebay shortram intake filter to k&n filter. the problem is that at idle engine starts to fluctuate at 1000-400, but only when A/C is on. if A/C is off, rpm's are stable at ~650. if i put back on the old filter rpms ar stable no matter if A/C is on or off, with A/C its ~800, without ~650.
i have tried to disconnect battery, tried Throttle Valve Closed Position Learning procedure and Idle Air Volume Learning (Throttle Position Learning) procedure. but nothing helped.
what could be the problem (with old filter everything is normal). and if i take off filter (start car without any filter) rpms are fluctuating as with k&n filter...
Old Feb 8, 2011 | 12:55 PM
tomykas's Avatar
bump?
Old Feb 8, 2011 | 12:59 PM
sTeadFasT96's Avatar
Are you sure you reconnected the MAF sensor? I did my test pipes recently, forgot the MAF sensor and it'd idle at 1,000 rpms and drop to about 500 about every 10 seconds or so and come back up. Also had the VDC, Slip, and Engine lights on. Hooked that sucker back up, resetted the ecu and it was just fine after that.
Old Feb 8, 2011 | 04:01 PM
tomykas's Avatar
i did try to disconnect and reconnect maf sensor. with disconnected maf rpms are stable at about 1000 rpm, slip check lights were on. after reconnecting maf and disconnecting and reconnecting battery everything is the same. same problem... everything is as was, i just changed the filter. and as i said, if i put on the old dirty filter, rpms are normal and stable...:/
Old Feb 8, 2011 | 05:11 PM
IHIERBal's Avatar
Try a ecu reset or idle reset with the new filter? Just a guess. Good luck.
Old Feb 8, 2011 | 05:41 PM
tomykas's Avatar
i wrote in the first post, that i did these steps, but none helped... wat concerns me that without A/C engine works ok, and rpms ar stable, but when i turn on A/C it starts to fluctuate
Old Feb 9, 2011 | 04:51 AM
tomykas's Avatar
bump? any suggestions?
Old Feb 10, 2011 | 04:45 AM
tomykas's Avatar
anyone?
Old Mar 20, 2011 | 11:20 AM
tomykas's Avatar
bump? still having same problem.... nothing helps no one knows what it could be...
Old Mar 20, 2011 | 12:34 PM
ldg870's Avatar
I had a similar problem when I replaced my filter. It took several attempts doing the throttle body and ECU resets. Good luck. Be patient>
Old Mar 20, 2011 | 12:37 PM
tomykas's Avatar
i made those resets million times but how do i know if i make steps right? is there any indication for "ecu reseted succesfully" something like that?
by the way, i took battery our of car for the whole day, and it is still not resetted?
Old Mar 20, 2011 | 12:42 PM
ldg870's Avatar
Sorry I had that problem when I cleaned the throttle body not replacing the filter. Speaking of the throttle body. Maybe check to make sure nothing got sucked into it. Maybe changing the filter dislodged debris and made it to the throttle body.
Old Mar 20, 2011 | 12:52 PM
tomykas's Avatar
do i have to take off TB to clean it? or can i clean it mounted?
Old Mar 20, 2011 | 12:58 PM
ldg870's Avatar
I took it off. There's a diy video. Its pretty easy. Just be careful when handling it.
Herbbie Hablib
Forced Induction
Aug 11, 2015 06:22 PM
ClwMike
Jul 23, 2015 12:55 PM
vstypicals
Jul 20, 2015 10:55 PM
justgotg35
Jul 19, 2015 12:33 PM
