Changing from stock 17 wheels to 19 rays, what difference in feel will there be?
Old Feb 27, 2011 | 05:30 PM
LonghornGary's Avatar
Will ride be rougher, same, louder with like tires? Do they wear faster? Does mpg take a big hit? Thanks
Old Feb 27, 2011 | 07:14 PM
g-adabout's Avatar
1. The ride will be a bit rougher...and you will notice the bumps in the road as you will have less sidewall...
2. not the same ride, as you will sit higher off the ground now.
3. With simular tires, it depends on what tires. On the oem 19s, your inner tire wear will show up a little faster and the sound of cupping tires will annoy you until you get a camber and toe kit.
4. The OEM 19s are lightweight and forged aluminum wheels. The difference will be minimal on acceleration and mpgs....
Old Feb 27, 2011 | 07:19 PM
Thanks for the response, may just hold out for some 18 oems, i assume all the stated problems would be less pronounced.
Old Feb 27, 2011 | 07:22 PM
the_sedan's Avatar
/\what #2 said lol
you have nothin to worry about with runnin 19s tho
Old Feb 27, 2011 | 07:36 PM
pacman27's Avatar
19's will have a noticeably rougher ride, but not objectionable. They will look better than the 17's though. I think the 18's are your best bet if you want a bigger wheel but still want some ride comfort.
Old Feb 27, 2011 | 09:17 PM
walshtj's Avatar
^Def but the look of ray 19s in worth the worse ride.
Old Feb 27, 2011 | 09:28 PM
DogStar's Avatar
Weight is a lot lower on the 19s as well yet are still solid b/c they're Rays.
Old Feb 27, 2011 | 10:02 PM
SiouxFallsG35's Avatar
I run oe 17's winter, and oe 19's in the summer. I honestly don't notice the difference.
Old Feb 27, 2011 | 10:13 PM
4D05G35's Avatar
The ride difference between my summer wheels (19's) and my winter (18's) is very minimal and I contribute most all of that to the softer compound of the winter tires.
The slightly larger sidewall of the 18's does asorbe some of the bumps, but not enough to keep me from my 19's.
If the only reason that you are going with 18's over 19's is for ride quality...you will be dissapointed. If you ever try on a set of 19's you wont notice much of a difference when it comes to smoothness and noise.
Old Feb 27, 2011 | 10:34 PM
fstasfk_G's Avatar
ur speedo will slightly be off, but that can be re-adjusted
Old Feb 27, 2011 | 10:41 PM
cpufreak3's Avatar
Agreed. I run OEM 18s in the winter and OEM 19s in the summer. To me, they're both equally harsh. The only thing I've noticed is more road noise from my 19s, but that's probably due to low tread.
Old Feb 28, 2011 | 12:05 AM
maclovio's Avatar
Your car will look A LOT better...i dont think nothing changes mpg wise. Just the camber. i would never get any other rim size.
Old Feb 28, 2011 | 12:35 AM
AnJingG35's Avatar
i just recently switch from OEM 18's to the rays 19.....there is a lot more road noise and the ride is bumpier than b4, but its worth it
Xfactor
Dec 1, 2019 12:52 PM
teamghost
Jul 28, 2015 04:52 PM
realtalk21
Jul 20, 2015 09:07 AM
justgotg35
Jul 19, 2015 12:33 PM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
