Rear window trim necessary?
Old Mar 18, 2011 | 10:49 PM
jstudrawa's Avatar
The trim on the upper edge of the rear window is coming up at both ends.
Is this a necessary piece or just for looks? It doesn't stop water from getting between the roof and widows. It doesn't seem to actually seal anything.
Can I remove it without problems? I'm not a fan of epoxies, they never last long.
Thanks.
Old Mar 20, 2011 | 01:18 PM
ldg870's Avatar
Not sure what trim you're talking about. Is the window tinted? Could it be the window tint peeling off? Post a pic.
Old Mar 21, 2011 | 01:18 AM
Gdriver90's Avatar
Thanks.
it helps seal the window, if its coming up i recommend taking it off and replacing it so you dont develop a leak down the line.
Old Mar 21, 2011 | 02:08 AM
TIAN's Avatar
Hold The Line
Pic please.
There is a strip on top of the rear window that covers the satellite installation wire line. I took mine off when I took off the sat antenna. Not sure if that is what you are referring to hence the pic request.
Old Mar 21, 2011 | 01:57 PM
jstudrawa's Avatar
Here's a pic, sorry.
Looking at it, doesn't seem to close the gap properly, so I can't imagine it's waterproofing anything...
Could very well be the sat wire, though.
Old Mar 21, 2011 | 01:58 PM
Gdriver90's Avatar
hmm, thought it was something else. not sure what that is. i dont have one...
Old Mar 21, 2011 | 02:15 PM
SemperFi2k1's Avatar
It is just the trim piece that covers the sat radio wire. Mine was having the same problem and I just took it off and replaced the double-sided tape that holds it on.
Old Mar 21, 2011 | 02:17 PM
jstudrawa's Avatar
Semper, it's just double sided tape holding the sat wire on? You completely removed the trim piece?
I think the car would look cleaner without the trim piece, personally.
TIAN's Avatar
Hold The Line
Not needed. You can peel it off. It's only held on by double sided tape.
Old Mar 21, 2011 | 02:21 PM
jstudrawa's Avatar
Thanks, Tian. I'll do that.
Won't have any issues with the sat antenna, correct?
Edit: Damn, I need to break out that bottle of Back to Black I bought, my trim is looking rough.
Old Mar 21, 2011 | 02:23 PM
TIAN's Avatar
Hold The Line
I took mine off so I couldn't say for sure. I'm sure the wire is properly insulated for weather but after awhile it may erode.
Old Mar 21, 2011 | 02:53 PM
It should be fine if you take it off. I drove around with out it for a few months and it didn't effect anything. But yeah, the trim piece is just held on with double-sided tape. The wire just sits in the grove above the window.
tiguy99
Mar 1, 2016 11:42 AM
leo38cheng
Nov 12, 2015 06:49 PM
Gip
Aug 24, 2015 05:31 PM
ev_g35
Interior
Aug 14, 2015 02:05 PM
apintojr
Jul 23, 2015 10:52 AM
