Question regarding compression rod bushings
Old Mar 24, 2011 | 06:58 PM
scottkusf's Avatar
Hello - I recently moved to California and my new Infiniti dealership screwed me over. Nevermind the screw over, but after leaving I noticed on the paperwork some recommendations. I can get these done at another mechanic but I wanted to know just how dire or important these were.
1. Compression Rod Bushings (torn) - I have done some research and it seems like this just causes some clicking noise? Is this a critical part to my car that needs to be fixed to drive safely and not cause more damage to the car?
2. Rack and Pinion Steering (leaking) - Apparently it is leaking a little bit of power fluid. This sounds more like an issue that I will get checked out. Should I check the power steering in the meantime?
The main issue I am worried about is the compression rod bushings since they wanted $1500 to do it.
Thank you very much.
Old Mar 24, 2011 | 07:18 PM
bocatrip's Avatar
I started a thread on this very subject in July of 2007. If you have the patience to read close to 400 posts you may gain some info on this very subject. The name of the thread to do your search on this forum is "G35 Compression Rods are Total Crap". The thread is still alive and well with recent posts. I would think your power steering leak to be of more concern. Good luck.
Old Mar 24, 2011 | 09:59 PM
jibberjabbers's Avatar
$1500 for the compression rod bushing? Damn!
You can buy the bushings for about $50 / pair. Just buy the bushings yourself and take it to a local garage.
http://cgi.ebay.com/ebaymotors/OEM-I...Q5fAccessories
Old Mar 24, 2011 | 10:23 PM
jutn35's Avatar
G35 Coupe
Lol. Compression rods do not cost that much for parts and labor. For me it was around 400 and bushings under 100
Old Mar 25, 2011 | 03:55 AM
fatlip's Avatar
Or u can get the SPL compression rod bushings and never ever ever have to change them out again. OEM bushings are fine at $50 a set but they will go out again sooner or later.
MyfistYourFace
Aug 8, 2015 11:58 AM
kinetek
Aug 3, 2015 04:25 PM
keithk831
Steering & Suspension
Aug 2, 2015 09:50 PM
itschuckster
Jul 25, 2015 08:07 AM
LoSt180
Jul 15, 2015 08:31 AM
