Help window stuck down!!!
Old Mar 25, 2011 | 05:15 PM
AJ100206's Avatar
Brakes
yeah i had the same problem about 3 months ago..bought a new window motor..was fine for about a month and it is doing the same thing as before...what could this be????
Old Mar 25, 2011 | 05:22 PM
Keggr626's Avatar
Okay so after hitting the door a couple of times the window just went down. further (womp womp). I brought the car to my friends shop, took the door panel off and followed the DIY on how to clean the motor... I'm proud to say its working again! Thanks guys for all the help. I appreciate it!
Old Sep 13, 2014 | 03:16 PM
Mrunow's Avatar
Good advice
Originally Posted by Keggr626
So rightnow on my way home my window decided to take a s*** on me while rolled halfway down. I already know its a common problem on the G. My question is, is there anyone that knows how to get the window back up for now untill I get the motor replaced? Ps. ITS STARTING TO RAIN! 2004 coupe
I can't believe this worked! Just above the back end of the armrest worked for me.
Old Aug 28, 2019 | 11:15 AM
07Sport's Avatar
G35 Coupe Sport and Premium Packages
Thumbs up
Originally Posted by R10T_x
i had the same problem a while back i just slammed the door and it worked lol this might not work for u but it was a quick fix for me while i waited on a new window motor
This worked for me perfectly. Much appreciated I'm shocked.
Old Aug 4, 2020 | 01:48 AM
Robert000's Avatar
2004 g35
Window now fixed
Originally Posted by Project
All of you that it worked probably had a chunk of dirt in it and just needed to be cleaned. The seals are not the best and they get dirt and corrode. A good cleaning will usually do the trick. If not theres a kit that will rebuild the part that you actually need to replace not the whole motor.
man, i replaced window switch and motor which got the window working again. Same problem returned a month later. Tried Cleaneing motor and still wont roll up. Finally decided to take the window regulator apart and cleaned it thoroughly(the mechanical rails that hold the window). Then regreased everything. Window now rolls up smoothly and faster as the day I bought it from the dealer.
I also put back the old switch and motor and works just fine. It was never a motor issue in my case. Just dirty rails that needed grease
Dallsinghjr1
Sep 17, 2023 11:25 AM
Picture Share
Feb 4, 2018 12:41 PM
BradMD_96
Oct 6, 2015 09:31 AM
dcsbh1
Oct 1, 2015 03:15 PM
Learned Hand
Oct 1, 2015 09:02 AM
