ok so my headlights are foggy/turning yellow. I did some search and saw that PlastX was a good product to use. However, one thing I didn't get from the threads I read was when people were asking if they were fogging from the inside or outside. How am i supposed to tell? and what is it meant when you "wax" them so they dont fog up again. Thats the 2 things I didnt understand, so any help would be awesome.
I use ScratchX on my headlights, works great. Takes all most if not all of the cloudy marks.
PlastX would probably work even better. Meguairs stuff works wonders.
Yea I heard good things about it too. I'm just wondering what people mean by "waxing" the headlights after so it doesn't go back to cloudiness.Originally Posted by Calamity
I use ScratchX on my headlights, works great. Takes all most if not all of the cloudy marks.PlastX would probably work even better. Meguairs stuff works wonders.
Most people believe the yellowness is caused by the sun... basically when u buff and wax ur lights ur protecting them from the sun and other elements just like u would ur paint.
Quote:
Ahh I see. Any wax you recommend then?Originally Posted by Keggr626
Quote:
That exactly I would not knowOriginally Posted by Mark2K8
Avoiding potholes
Grace
Avoiding potholes
close
- Join DateApr 2006
- LocationSF Bay Area
iTrader Positive Feedback0
iTrader Feedback Score(0)
Liked:150 Times in 110 Posts
I used a 3m headlight lens restoration kit on my head light and that worked really well for me. you need a standard power drill for that though.
Tabris
close
- Join DateFeb 2010
- LocationSK, Canada
iTrader Positive Feedback100
iTrader Feedback Score(3)
Liked:42 Times in 22 Posts
I used some plastX on my old headlights, it didn't amaze me, but I only applied it by hand (I put in as much elbow grease as possible..). If your car is an 03-05 coupe you could consider some new 06+ headlights. That's what I did, can't get cleaner then brand new
You can use metal polish as well to clean the headlights. Most of the time, plastX is not abrasive enough to remove stubborn yellowing/haze. I have used Blue Magic metal polish with great results.
You can use any wax as protection afterwards but some will work better than other.
Klasse High Gloss Sealant Glazeis my go to sealant for headlights and windows.
Quote:
How did it last? Did it start hazing up again after a while?Originally Posted by DVan
thanks
Quote:
projectors arent an option at the moment :/Originally Posted by Tabris
thanks ill look into itOriginally Posted by Gdup35sedan
You can use metal polish as well to clean the headlights. Most of the time, plastX is not abrasive enough to remove stubborn yellowing/haze. I have used Blue Magic metal polish with great results.You can use any wax as protection afterwards but some will work better than other.
If your headlights are fogging from the inside.. then you're kind of SOL.. i've got that problem on my right headlight. It's a huge pain in the *** to take out the headlight because you've got to take off the bumper and all that fun stuff then stuck the headlight in the oven and etc etc.
PlastX works great though.
That's the thing I dont understand. How do i know if its inside or outside fog...? I guess if PlastX doesn't work very well then presume its inside fog..?Originally Posted by prinny
If your headlights are fogging from the inside.. then you're kind of SOL.. i've got that problem on my right headlight. It's a huge pain in the *** to take out the headlight because you've got to take off the bumper and all that fun stuff then stuck the headlight in the oven and etc etc.PlastX works great though.
Quote:
I doubt its in the inside but u never know... is it foggy like moisture, or is it just yellow and hazy?Originally Posted by Mark2K8
