Stp oil filter
Old Apr 7, 2011 | 11:05 PM
MADtotheA's Avatar
Stp oil filter
Is this a decent oil filter for the g35 coupe? Also, when I get my oil changed at a shop, do they put a new crush washer in or do they use the same one? Thanks
Old Apr 8, 2011 | 07:24 AM
superchargedg's Avatar
Junk oil filter and most shops dont replace the crush washer.
Old Apr 8, 2011 | 07:36 AM
MADtotheA's Avatar
Haven't seen any threads on why it's junk. What makes it junk through your experience? If they don't replace the crush washer, could I e xperience serious problems?
Old Apr 8, 2011 | 08:13 AM
EL-EE-ES's Avatar
crush washer should be good for a few oil changes....i change my crush washer every 3 or four oil changes, the dealer says it should be changes every change but if never had a problem. the washer is only cost a few cents at the dealer, so buy some and have the shop replace it.
Old Apr 8, 2011 | 08:18 AM
EL-EE-ES's Avatar
for oil filter i like to use k&n or mobil 1.
i did a quick google search on stp since i never seen one being use by a g35 owner.http://www.bobistheoilguy.com/forums...Number=1530354
Old Apr 8, 2011 | 08:27 AM
MADtotheA's Avatar
Ok thanks guys. The last oil change was at the dealer so I should be fine. I'm still going to ask the shop to replace it today. I guess I'll just use this filter for 3,000 miles then go with something better for my next change that can last about 5,000 miles. I'm using mobile 1 5w 30. Thanks again
Old Apr 8, 2011 | 10:40 AM
gary c's Avatar
MadtotheA, the crush washer only needs to be replaced if there's a leak so don't panic....I've never replaced mine!
Gary
Old Apr 8, 2011 | 01:52 PM
MADtotheA's Avatar
Gary
Woosah! I actually went back to autozone and bought the mobile 1 filter then stopped by the Nissan dealership and got a crush washer for free. Guess I'm good to go now! Thanks guys!
Old Apr 8, 2011 | 02:55 PM
Mobil 1 filter is good as is the pureolater pure one,wix,napa gold to name a few.
Old Apr 8, 2011 | 03:10 PM
FuSiOn's Avatar
I just went to Advanced Auto Parts, they had a special on castrol oils... with 5qt purchase you receive a free k & n oil filter for $27.99
...If you get lucky like i did, they had the sign in front of the Castrol EDGE platinum oil where it did not belong, thus i got that oil and the k & n filter for 27.99, not a bad deal on my end
Old Apr 8, 2011 | 03:34 PM
MADtotheA's Avatar
That's a dam good deal. I got my mobil 1 oil at walmart for $24 and the filter at autozone was $12. Maybe I can be lucky like you one day
Old Apr 8, 2011 | 10:31 PM
AuAltima3.5's Avatar
The STP filter should have a plastic "cage" on the inside. These filters are the 'e-core' design that a few manufacturers use that seems to work pretty well. BITOG (Bob Is The Oil Guy) can help you with oil filter selection. I use OEM filters, which get mixed reviews, but really keep my chain rattle at start-up to a min.
I also replace the crush washer every oil change. They are super cheap.
KruZZe
Feb 27, 2023 05:04 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
mbe32
Nov 13, 2015 11:09 PM
9tray turbo
Sep 29, 2015 10:22 PM
vamarris
Sep 26, 2015 12:56 PM
