Rust on my G coupe *help*
Old Apr 10, 2011 | 02:00 AM
sunnyice's Avatar
I was cleaning my car when i noticed some rust spots on driver side rear wheel well(not sure if thats what its called). i have pics that im trying to upload.
I also checked my exhaust and i saw that it was cracked from the flange at the rear ( the one closest to the muffler) i will try to upload pics for that soon.
whats the best solution for my problem?
Old Apr 10, 2011 | 02:27 AM
TofuProductions's Avatar
sand down and get touch up paint or have bodyshop fix it.
Old Apr 10, 2011 | 02:47 AM
sunnyice's Avatar
that part is getting deformed as you can see it from the pics. is it rusting from the inside?
Old Apr 10, 2011 | 02:48 AM
Affalterbach's Avatar
easy fix. ^^^^^^
Old Apr 10, 2011 | 03:15 AM
sunnyice's Avatar
Originally Posted by Affalterbach
easy fix. ^^^^^^
Do you mean it can be easily fixed by a body shop?
Old Apr 10, 2011 | 03:17 AM
nogoodname's Avatar
The flange can be welded. happened to me and many other g35's from what my dealer said. So it's a common thing.
Old Apr 10, 2011 | 03:22 AM
sunnyice's Avatar
yea someone with a g35 also told me that its a common problem on g35's but he said its hard to get it fixed
Old Apr 10, 2011 | 09:25 AM
g35guy86's Avatar
Isn't body corrosion covered under warranty up to 100k/10yr?
Old Apr 10, 2011 | 11:32 AM
sunnyice's Avatar
mines a 2005 with 104,000 kms. did you mean miles? ill take it to the dealership on monday and ask them about it. thanks for the reply's.
Old Apr 10, 2011 | 11:34 AM
brenty_blanco's Avatar
I believe that is correct.
I would take it to the dealership and see what they say before trying to fix it yourself.. but worse comes worse, pretty simple fix. Good luck.
Old Apr 10, 2011 | 11:40 AM
fabb's Avatar
no its 7yrs unlimited km..have the same issue on my 04, but my car was on the road in 03 which makes it over 7yrs so infiniti wont cover it under warranty..sucks
Old Apr 10, 2011 | 11:46 AM
sunnyice's Avatar
do you guys know if its the same in canada?
Old Apr 10, 2011 | 04:13 PM
sunnyice's Avatar
ok i looked it up and i found this:
CORROSION WARRANTY
Surface Corrosion
Surface corrosion of any body sheet metal is covered by the 48
month/100,000 kms. Basic Coverage. Surface corrosion means
corrosion affecting any readily visible surface area of any
component of the vehicle body, but not including the vehicle
underbody.
For additional information, refer to the “Limitations” and “What is
Not Covered” sections on pages 8 through to 10.
Perforation from Corrosion
Original equipment vehicle body sheet metal components are
warranted to be free of “Perforation from Corrosion”, defined as
rust through, from the inner surface to the outer surface, resulting
in a hole. The duration of this warranty is 84 months, unlimited
kilometres from the warranty start date *. For additional
information, refer to the “Limitations” and “ What is Not Covered”
section on pages 8 through to 10.
As im passed 100k am i eligible for the second one? it talks about perforation that i dont have yet but i know it going to get there if i just neglect it.
What should i do if the dealer tries to deny my warranty claim? as they always do from my experience.
Old Apr 11, 2011 | 10:23 AM
sunnyice's Avatar
I just came back from the stealership and those *******s said it won't be covered because there's no perforation. One of the service guys told me to apply some rust inhibitor/Protectant and forget about it.
Should I just sand it myself? Iol I'm not sure if I can do it my self.
Can someone give a detailed explanation on how to do it? Pls?
Old Apr 11, 2011 | 10:31 AM
TannerG's Avatar
^^ Well there isn't perforation is there?
If you're not sure you can do it yourself, take it somewhere.
