will i be running lean?
Old Apr 15, 2011 | 12:08 PM
cmesidewayz's Avatar
after searching i saw people talking about running lean but the threads were really old, around 04. so i thought i would get some better answers
i know the 05's have a different ECU
I have an 05 with 29k
with test pipes ( hfc's coming this week), MD 5/16 iso thermal, MREV2 and z tube will i run lean ? i wont have a chance to dyno the car until a few weeks after the mods are on and I just want to make sure my afr will stay in check
hopefully tony can post some info too
thanks guys !
Old Apr 15, 2011 | 12:16 PM
idrivetsi's Avatar
i think you will be good...nothing the stock ecu can not handle...not like you are supercharging or turboing the car...
idrivetsi's Avatar
if you are really that worried...just take it easy on the car until you get it tuned...
Old Apr 15, 2011 | 01:43 PM
Silencer_0's Avatar
The ECU can handle that. Just reset it after you intall your mods.
Old Apr 15, 2011 | 01:48 PM
yeah il reset the ECU after the install using the pedal method.
Silencer_O... were you running lean before your osiris tune ? jw since you have a few more breather mods than i am going to have
Old Apr 15, 2011 | 01:59 PM
Silencer_0's Avatar
A little. Not to the point where I needed a tune, but obviously it's best to have it. First time I got tuned, I had my exhaust, spacer, HFCs, and intake. I had to get a retune after I switched to my ART pipes.
Old Apr 15, 2011 | 02:02 PM
walshtj's Avatar
^ It may be a little but not significant enough to effect anything. Good choice of mods also!
Old Apr 15, 2011 | 07:53 PM
Thumbs up
do you know what your afr was when you had that first tune ? also if i was running lean couldn't i look at my temp gauge and see if its above normal ?
sorry about all these questions i just like to be 100% sure, i plan on having my G till she is no longer repairable so i dont want to hurt engine life the slightest bit
theres no other car with the lines of the G
Old Apr 15, 2011 | 07:54 PM
thank you ! little more expensive than i hoped but it should be worth it !
Old Apr 16, 2011 | 03:37 AM
andrewstclair's Avatar
i wouldn't worry about it at all these cars are actually tuned quite rich from factory for an N/A car. the test pipes i think set off a code though unless the lower 02 sensor or spaced out from the pipe.
Old Apr 16, 2011 | 10:38 AM
^ yeah when i put my test pipes in my service engine light came on in like ten minutes
Thebaws11
Jul 2, 2021 11:36 AM
Thebaws11
Nov 30, 2016 12:54 PM
Vqalexisz
Oct 14, 2015 12:48 AM
Rhinos7777
Sep 6, 2015 05:36 PM
n2fooz
Sep 4, 2015 07:46 PM
