window malfuntion help
Old May 3, 2011 | 02:37 AM
Nab's Avatar
Nab
Originally Posted by Deezflip
yeah the window motor in these things suxxxz, I find myself cleaning and resetting it once a year. FYI, cleaning is required if you find your window completely dead and stuck. Resetting is required if your window moves but irregularly and in some possessed kind of way.
Better get use to the being a DIY type of person. Even after getting a new window motor will eventually fail again on you.
Yeah, it's about time i clean my driver side window. What would you suggest in terms of a process w/ materials. i guess people are using some rubbing alcohol??? gotta get used to doing this.
Old May 3, 2011 | 11:21 PM
Deezflip's Avatar
^i used electronic cleaner(non-residue type) from Radioshack and gushed the hell out of it. I sprayed it while holding it upside down so the dirt drips out. It's almost like pressure washing it with this stuff, except it dries almost instantly. It comes in a spray can with a straw attachment similar to the ones that comes with WD-40, brake cleaner, etc.
I also used sandpaper or brillo pad for the carbon build-up and an air blow gun as well. Basically, I clean it like I'm gonna eat off of it! However, make sure you leave the parts that was meant to be greased. If you accidently cleaned it off, just regrease it.
Old May 4, 2011 | 07:06 PM
bocatrip's Avatar
Common problem along with actuators. I had mine replaced one year after purchasing the car new under warranty. I've heard of members changing them up to 3 times. It's too bad Infiniti never upgraded the motor to an improved part.
Dallsinghjr1
Sep 17, 2023 11:25 AM
Picture Share
Feb 4, 2018 12:41 PM
BradMD_96
Oct 6, 2015 09:31 AM
dcsbh1
Oct 1, 2015 03:15 PM
Learned Hand
Oct 1, 2015 09:02 AM
