CRANKshaft position sensor DIY
Old May 31, 2011 | 07:12 PM
jsmith29's Avatar
Hey guys,
I took my 04 6mt coupe to have the codes read. P0335 - crank position sensor circuit. I'm seriously considering DIY on this as the sensor is easy to get to with a jack, and the stealership wants 200 in labor for it.
Any reason I shouldn't DIY on this, or anything I should know going into it?
There is a BWD sensor at pep boys for 45 bucks.
Thanks!
PS i tried searching and couldn't find but one thread on it that was rather lacking in information.
Old Jun 1, 2011 | 01:40 PM
TannerG's Avatar
DIY
https://g35driver.com/forums/engine-...-camshaft.html
Old Apr 17, 2012 | 10:58 AM
OMG35X's Avatar
Crankshaft position sensor
Originally Posted by jsmith29
Hey guys,
Thanks!
My 05 g35x stalled about 3 times in a week both while idling and at 40 mph and finally threw a code p0335 . I found the crankshaft position sensor at Autozone for $42 duralast. The sensor is located on the driver side right between the engine and transmission. It's easiest to get to on a lift since you have to remove the lower engine shield but you can get to it from the drivers front wheel well with the car on a jack stand. There is only one bolt holding the sensor but removing the connector is the challenge. Be careful not to break the clip!
Freeman186
Sep 6, 2023 10:07 AM
wuzz-upp
Oct 3, 2015 04:21 PM
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
vamarris
Sep 26, 2015 12:56 PM
n2fooz
Sep 4, 2015 07:46 PM
