'03 Coupe AT- Triptonic question
Old Jun 14, 2011 | 02:44 PM
03XG35's Avatar
I was driving the other day and decided to go triptonic. When I moved it over to the + it would just stay in the middle and I couldn't go to + or -
WHat is the + and - for? And how to I turn it on, thanks
Old Jun 14, 2011 | 04:34 PM
DrewDrew's Avatar
were you actually driving or stopped when you tried shifiting? if you're stopped at a light or something, you can't shift, that's just the way the car's programmed.
if you are driving down the road, just pop it over to tiptronic and shift up/down. if that's what you were doing, and it still wasn't working, then have your mechanic check it out. it's usually a solenoid that's gone bad. a guy had the same problem in his '08 sedan. he made a thread on it this weekend.
Old Jun 14, 2011 | 06:08 PM
jutn35's Avatar
G35 Coupe
jeezus -_- GOOGLE or read your damn manual
Old Jun 14, 2011 | 06:17 PM
GeeWillikers's Avatar
Walking The Fine Line...
Great post. So happy you took the time to try to help a fellow G owner.
Give us more specifics about what was going on if you like, but timmy4me nailed it.
If you were stopped it was not shifting by design. If you were rolling, it should have been working as you'd expect.
The ' + ' means shift up and the ' - ' means shift down. It's on automatically as soon as you slide the stick over to manual mode.
Old Jun 14, 2011 | 06:23 PM
03XG35's Avatar
I was driving, but I did not press the gas at all. I heard you may have to have it up to like 2.5 RPM to switch?
Does the + mean its fast or what?
Old Jun 14, 2011 | 06:37 PM
DrewDrew's Avatar
"does it mean its fast?"
+ just means up shift. that's it.
- means downshift.
I've never noticed if I've had to have my foot on the gas or not to upshift. I know it'll downshift at any time, so I doubt you have to gas it to upshift.
Old Jun 14, 2011 | 06:43 PM
Mark2K8's Avatar
Thats how it is. The stick doesn't stay in the + or the -. You push it up or down and it will shift and return to the middle. Thats how its supposed to be. You have to be at a certain RPM to shift up (or down) sometimes. Like if you're going 10mph you probably can't go higher than 2nd gear. You can keep pushing it up to + and it will still stay in 2
Old Jun 14, 2011 | 06:51 PM
03XG35's Avatar
THANK YOU! I had no idea how it worked lol. I thought the stick would either stay in + or -
Old Jun 14, 2011 | 06:54 PM
PerpetualVisitor's Avatar
Oh i see, OP thought it was like a performance mode and like a... sucky mode or something. Nope its something to control the gears
Nicksims13
Oct 15, 2015 01:57 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
kd03g99
Jul 30, 2015 11:24 AM
mushu
Jul 15, 2015 03:55 PM
