Tranny or Flywheel Making Noise
Old Apr 21, 2003 | 09:26 PM
wreck's Avatar
Running for his life!!
After installing my Stillen Filter and went ofr a test drive, in the garage I noticed my tranny was making noise. Not sure if this is normal. But when I press the clutch in the noise goes away.
Is this normal? I'm letting the car cool down now and going to fire it up to see if the noise is still there.
G35C 6MT / E55
Old Apr 21, 2003 | 11:02 PM
RamboRami's Avatar
G35driver.com Moderator
Re: Tranny or Flywheel Making Noise
is it a frequent ticking noise? it could be coming from somewhere near the intake... sometimes this happens with these cone filters...
<font color=green>-Ramb0</font color=green>
Old Apr 21, 2003 | 11:34 PM
wreck's Avatar
More of a silent gargling noise. Only happens when the clutch is not depress. I can hear it pretty well when I'm in the garage, but not to bad outside.
G35C 6MT / E55
Old Apr 22, 2003 | 01:31 AM
ReDRoK8's Avatar
Mine is doing it too. I'm worried it's the throw out bearing for the clutch. My toyota truck made a simliar noise before I had to have the throw out bearing replaced. **Sigh** I'll check with the dealer. [sad]
-Jason
Laser Red '03 6MT
Old Apr 22, 2003 | 02:05 AM
wreck's Avatar
Gah!!
Keep me posted in what the dealers says.
I'm hoping this is a normal thing and all 6MT's do it. Hopefully other people will check it out and all of them come out with the same result. If you other guys check, make sure you are in a garage so you can hear what I am talking about.
G35C 6MT / E55
Old Apr 22, 2003 | 07:24 AM
retret's Avatar
Mine did this but I thought this is normal, there is always a differnet sound when clutch is fully depressed, this is because the plate start spinning when you're not pressing the clutch..I was told that this happens to some cars and some cars you dont hear a difference..
Old Apr 22, 2003 | 07:38 PM
Growler's Avatar
I have had the same clutch engagement noise in the neutral shift position from day one. I have always considered it normal as the clutch plate is in contact with the transmission turning some goodies inside. Your heaing the goodies in the tranny not the engine or clutch plate. The change in noise is more noticable when the power train is cold. The noise goes away when you press down on the clutch to disengage it. Thats my take on the topic.
Old May 4, 2003 | 11:36 AM
wreck's Avatar
Found out what the noise was. It's my syncro's. This is not a normal sound. I went to an infiniti dealer and they said they will probably have to change the tranny. I just have to make some time to do this.
G35C 6MT / E55
Old May 4, 2003 | 12:48 PM
Fiebru's Avatar
What's up with the G35C's tranny? I keep seeing posts about people's concerns with it.
Old May 4, 2003 | 03:38 PM
COUPEDIT03's Avatar
The tranny's are shot....Im on my second one...and i think a third one is on the way....random gears grind all the time..mostly 2nd, 3rd and 5th at random times...the clutch is fully depressed....the snycros are just shot in these tranies...We should have double or triple cone syncros like the ones found in the subaru impreza sti...that is the smoothest shifting tranny in the world...IMO
"Dont start none, won't be none"
Old May 4, 2003 | 04:16 PM
Merlin's Avatar
Staff ALUMNI
And some here were looking down on the STi. Hmmmmmh? You'd figure that Nissan builds the Skyline with pretty good trannies...... But I guess they had to cut corners somewhere.[img]/w3timages/icons/frown.gif[/img]
Old May 4, 2003 | 04:49 PM
COUPEDIT03's Avatar
Yea It would have been nice to have the r34 gearbox in our cars..but I guess it just doesn't bolt up to the motor...plus the gears would have been diff cuz of the turbos...maybe it wouldnt be so nice..nonetheless.....hopefully soon there will be a fix or for the 2004 model year they will have corrected this problem...This could possibly hurt the resale value of our Gs in the future, because it is a big problem.
Old May 4, 2003 | 08:37 PM
RamboRami's Avatar
700 miles on my 6MT and no problems so far
rezendvous420
May 31, 2020 01:26 PM
Cskeet
Drivetrain
Dec 3, 2015 09:18 PM
Frostbite91
Aug 20, 2015 07:20 PM
Jussaku
Jul 29, 2015 11:45 AM
joedaddy1
Jul 28, 2015 02:58 PM
