Shifter Movable w/o Depressing Clutch
Old Dec 9, 2004 | 02:06 PM
G3NUI5's Avatar
Took my car in to Infiniti Service because I noticed I could shift from 2nd to Neutral w/o depressing the clutch at all. Infiniti tells me this is completely normal for the G35. I'm no expert on cars, but I thought the clutch was a little more involved with the transmission and shifting gears. Need some advise on what to do.
Thanks
Old Dec 9, 2004 | 02:27 PM
mrmcderm's Avatar
If done correctly, you can shift from 2nd all the way up to 6th, and back down to 2nd without ever touching the clutch. I used to do it all the time in my WRX when my leg got tired from Chicago gridlock (haven't tried it in the G yet...because of the wider torque curve, I find myself not shifting as much in traffic)
All the clutch does is allow you to unload the gearbox to make meshing up the gears easier. But if you time things and rev match correctly, you can mesh the gears up when there is little or no load on the input shaft, and you can usually slide right into gear.
Old Dec 9, 2004 | 03:35 PM
Msedanman's Avatar
O.F. Administrator
Thanks
You can do all the shifts without a clutch, but that takes mucho practice and a little luck to do it without grinding.
The service peeps are right. Your ride is ok.
Old Dec 9, 2004 | 07:23 PM
Aznteazer's Avatar
how did you notice that you can shift out of 2nd gear without the clutch?
did u accidentally hit it out or did u just try it for the heck of it?
jus curious.
Old Dec 9, 2004 | 09:34 PM
StVincent's Avatar
seems pretty normal. on my previous ride: 94 teg gs-r, i could shift it from 2nd to 5th without depressing clutch, only at the right moment though... i don't know if this will cause any harm on tranny, but yes, it's doable.
Old Dec 10, 2004 | 07:15 AM
jdl75's Avatar
Absolutely correct. It takes a little practice, or a little luck, but a good set of syncros make it fairly easy, if the tranny is unloaded. Coasting is a good time to try this - just go slow on the shift, and you must rev-match very well. I don't recommend that you try this too often, as it does put additional wear on your syncros if you are off on your rev match by mutch.
Old Dec 10, 2004 | 12:25 PM
kenchan's Avatar
It's normal. When there's load on the drivetrain it'll be tough to get out of gear,
but when there is no load or rpm's matched, the shifter will not only go into N,
but you can gently push it into another gear w/o clutch-in as well.
Old Dec 11, 2004 | 02:13 AM
G3NUI5's Avatar
jus curious.
It's slipped a few times on it's own. I was just trying to recreate the slip w/ my gf in the car for a 2nd opinion. Thanks for all your responses.
Old Dec 11, 2004 | 12:00 PM
KarateBoy's Avatar
What is the rev-match?
Just keep pressing on the gas till X revolutions and push the gears into place?
Old Dec 11, 2004 | 02:14 PM
G5pot's Avatar
yeap, Just keep pressing on the gas till X revolutions and push the gears into place.
To get the gears out hit the gas while in gear then shift out right after letting go of the gas without depressing the clutch, if timed right it will smoothly shift into neutral. Then rev match to get into the next gear without depressing the clutch.
I heard this was a way of speed shifting.
RichardP9
Drivetrain
Oct 26, 2015 11:25 PM
alessandro
Oct 8, 2015 09:29 AM
AL8782
Oct 3, 2015 10:26 AM
Jpete
Sep 25, 2015 01:38 PM
