What sensor is this?
Old Aug 1, 2011 | 03:39 AM
So while changing my oil today, I noticed the sensor pictured was broken, dont know if it's from driving , or if I accidently broke it while making a hole on the oil filter in order to loosen it . sensor is directly behind the sway bar, took my car out for a spin, everything seemed fine, but I did have a check engine code, but that was there already since I have a bad O2 sensor
http://www.flickr.com/photos/61136499@N06/5996842713/http://www.flickr.com/photos/61136499@N06/5996842713/ by http://www.flickr.com/people/61136499@N06/, on Flickr
Old Aug 1, 2011 | 01:12 PM
Bump
Old Aug 1, 2011 | 01:18 PM
Philly_G35's Avatar
Looks like the oil pressure sensor to me, but I would check the FSM to be sure.
Old Aug 1, 2011 | 02:05 PM
rimshaker's Avatar
Just looked at the FSM, page LU-8 on 2007 model.
Looks like the oil pressure switch harness connector in the diagram.
Old Aug 1, 2011 | 02:29 PM
Thanks guys ^ any problems if I drive like this in the meantime?
Old Aug 1, 2011 | 03:06 PM
rimshaker's Avatar
I wouldnt take the risk just ignoring it, especially since it concerns the oil pressure system.
If no one here can advise further, call up the parts dept at the dealership. Maybe they have more specific info about it.
Old Aug 1, 2011 | 03:14 PM
GR6RR's Avatar
That's the clean up your oily mess sensor..
Old Aug 1, 2011 | 04:43 PM
Philly_G35's Avatar
They probably carry them at your local auto parts store and should only be $20 to $30. I wouldn't drive without it because if you lose oil pressure your dummy light will not come on. The chances of that happening are probably slim, but it's not worth the chance.
While your at the auto parts store you should pick up an oil filter wrench so you don't need to jab a screw driver through the filter to remove it.
Old Aug 2, 2011 | 06:59 PM
andrewstclair's Avatar
yea that oil pressure and its gonna leak oil when you change it dont forget to top it back up
Old Aug 2, 2011 | 07:04 PM
VictoriousG's Avatar
Stop being cheap and get it fixed Chris lol
Old Aug 2, 2011 | 07:38 PM
GR6RR's Avatar
The extra oil helps in keeping the engine well lubricated.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
KallDay86
Jan 8, 2016 12:42 AM
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
vamarris
Sep 26, 2015 12:56 PM
sullivan72
Sep 22, 2015 11:39 PM
