Any clue what's wrong with my suspension?
Old Aug 29, 2011 | 12:48 PM
My Key's Avatar
I've been told it's my toe alignment and/or bad compression rod bushings.
thoughts? It's also only happening on the front driver side tire. This is the inner shoulder. It doesn't even go all the way around. just sporadic. passenger side tire's fine.
Old Aug 29, 2011 | 12:50 PM
My Key's Avatar
If i recall correctly, I didn't feel any vibrations until i was going over the san mateo bridge and hit a bump or something... could be toe...
I rolled over one of these things and at the time, my tire pressure was relatively low. felt a big bump and thats when the vibrations started
Old Aug 29, 2011 | 01:11 PM
yadayada's Avatar
Same thing is happening to me. I replaced my tires last week thinking it would make the terrible rumbling sound go away but to no avail. It's almost like my rim may be bent. I really don't know. Let us know what you find.
Old Aug 29, 2011 | 01:21 PM
gary c's Avatar
One thing is obvious you need to find an independent brake/alignment shop in your area and find out if something isn't broken or severely worn out. Notice I didn't mention the stealership, there's a reason and a lot of them! $$$$
Gary
Old Aug 29, 2011 | 01:33 PM
My Key's Avatar
i've never seen anything like this before.. what the heck could cause my tire to do that?
Old Aug 29, 2011 | 02:12 PM
Frankieg35's Avatar
Dunno but go to an alignment shop asap.. they can check all your bushings and hubs..
Old Aug 29, 2011 | 02:24 PM
My Key's Avatar
yeah. i have an appointment after work. only problem is driving there.
Old Aug 29, 2011 | 08:13 PM
serges's Avatar
I have seen that before customer came in w that issue on the rear tires. I immediatley asked him if he had a shop or if he bought the tires. He said he bought them from online turns out his tire size was a lil too big and didnt use the directed size in the door jam rear tire were rubbing on the shocks hope that helps u
Old Aug 29, 2011 | 11:39 PM
My Key's Avatar
it's just happening only on the front driver side tire. My mechanic says its a faulty tire + bad toe.
Old Aug 29, 2011 | 11:51 PM
Marlin84's Avatar
You know, I think I noticed something similar on both of my front tires when I had them off to get at the headlamps.. The current tires are Yokohama S-Drives, have just over 30K miles on them, and it's the stock 17" rims. Replaced the rears about 4K miles ago (they were fried for a couple months before I got tired of having tires I could beat to hell because I knew they were already useless in rain and needed replacing).
I'll see if I can get a pic without taking them off. Or at least take a look and see if the wear is similar. But from what I remember, the wear was uniform between both passenger and driver side, and it was pretty much consistent around the circumference of the inside shoulder.. I'm riding on them as long as I can before I replace them, then it's straight to the alignment shop!
Old Aug 30, 2011 | 06:32 AM
Blue Dream's Avatar
I drove ttrank's car solo
The picture makes me think you have a bad tire. That ridge on the inside edge doesn't appear to be wear related, so maybe when you hit that joint it shifted the steel belts in the tire. The Federal SS 595s also have steel belts in the sidewall so maybe the jolt knocked belts loose or disfigured them.
sales@czp
Suspension-Vendor
26
Nov 6, 2017 03:04 PM
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
3-fity
Steering & Suspension
Sep 20, 2015 05:05 PM
reaper76
Sep 20, 2015 11:59 AM
Cbohannan101
Sep 12, 2015 10:32 PM
