Battery problem
Old Sep 20, 2011 | 03:57 PM
LakerFan1's Avatar
Unhappy Battery problem
Hey guys, yesterday my battery died so i called AAA and they came out and jumped the car. This morning when I woke up I went into the garage tried to start the car and no power. There is power to the dashboard and all the electronics (Fading away slowly as i can tell when i push the lock button on the key) So I was wondering, should I get a new battery or just jump it again and hope this time it'll work.
Thanks guys
- Jad
Old Sep 20, 2011 | 04:57 PM
saywat?'s Avatar
ugh new battery dude
Old Sep 20, 2011 | 05:00 PM
irishsig's Avatar
^+1 Yep, sounds like it's time for a new one.
I usually go to Sears and have them test the battery 1st.
Old Sep 20, 2011 | 05:07 PM
bluedevils95's Avatar
Just get a new battery! That should fix that problem.
Old Sep 20, 2011 | 05:08 PM
saywat?'s Avatar
^yup and sears will test out the alternator too jus to make sure its working
Old Sep 20, 2011 | 05:09 PM
LakerFan1's Avatar
Ight thanks guys! Any recomendations on which battery to get? Or does it not really make a difference? Not to car savy
Old Sep 20, 2011 | 05:13 PM
try this sight.
http://forums.nicoclub.com/need-a-ne...y-t443305.html
Old Sep 20, 2011 | 05:15 PM
saywat?'s Avatar
^jus be sure to get the one with the higher cold cranking amps. gives the car more juice when u start it
Old Sep 20, 2011 | 08:14 PM
Jg35skyline's Avatar
I had 2 batterys with in 4 years... whats with that???????
Old Sep 20, 2011 | 09:45 PM
LakerFan1's Avatar
Lol i think the reason for why mine is completely dead is cause when i moved here i bought the car but didn't have my license on me or even have the car registered so i couldn't drive it. so i would sit in the garage with the key in playing the music and F**king with the electronics and stuff. Had AAA come out and jump it once, ran for 2 weeks, last night died, jumped it, this morning dead. Idk why its dead haven't used it from the moment it got jumped to the time i woke up and started the car to give it a little charge but oh well. Guess I'm getting a new battery :P
Old Sep 20, 2011 | 09:53 PM
saywat?'s Avatar
iirc (forgot where i got this info from) once the battery charge goes under 12volts it loses its capability to hold the sufficient charge (12v) or something like that and u will eventually need to replace it anyway.
Old Sep 21, 2011 | 12:10 AM
manvelmk's Avatar
True, Got mine changed 2 days ago. I had the old one checked by Autozone, they said it was DEAD! Turned it in and got a discount. The new one is a bit less powerful, about 750 amps If I'm not mistaken. Starts the car just fine. Gotta test it really cold.
Old Sep 21, 2011 | 11:54 AM
LakerFan1's Avatar
Can someone please explain to me why a stronger car battery is better? other than itll prolly last longer why is it better to havea stronger battery?
-Jad
Old Sep 21, 2011 | 12:21 PM
smoovarrowhead's Avatar
I would recommend buying a cheap voltometer and test volts after sitting over night. then test voltage drop upon starting. sometimes all you need is a recharge after sitting. sounds like you do need a new battery but get the $10 voltmeter for future battery needs, there is tons of info online on batterys-how to test, optimizing battery life, etc.
Old Sep 21, 2011 | 12:28 PM
thescreensavers's Avatar
Mr.202?
OPs battery is dead and needs to be replaced
Sears get Die Hard Gold or Autozone Duralast Gold they are the same battery.
