Most power from N/A?
Originally Posted by dennis_said
Combination of plenum, intake, exhaust system, hiflow cats, headers, and ecu from technosquare. I believe that's what it is
light weight fly wheel
light weight clutch
Underdrive crank pulley
new cams
head porting
individual throttle bodies (which would scrap the plenum listed above)
lighter wheels
lighter tires
lighter brakes
Also there are several options besides the Techno Square ECU that are coming out. There is a new piggyback chip and another company doing the ECU reflash as well.
Please don't ask me about the cost of these items because I think you'd be getting near the $15K range... Also, no one has done all of this with the VQ35DE, so I have no reasonable idea as to how the hp/tq would turn out either.
-Neffster
Originally Posted by wuyichao
supercharger...
LOL ........ SVT if your done with every bolt on ont he car N/A you can possibly be up to 320 crank HP, that's with EVERYTHING (Intake,test pipes or high flow cats,pullies,plenum,exhaust,TS ecu) but if you wanted major power N/A with reliability you can always go for a "stroker" kit and bore out the motor to a larger displacement!! I have a thread on it from my350z, you might want to check it out! Dammit i lost the link, i'll try and find it!
-Adam
Has anyone ever proven that the stroker kit actually ADDS horsepower to a NA VQ35DE? I thought that beefing up the internals, dropping the compression ratio and all that fun stuff was just a "spring board" for going FI. Wouldn't dropping the compression ratio make the NA vehicle slower than stock?
the stroker kit ups the VQ to a 4.3 liter. you can choose whether to lower compression, or raise compression for pure N/A. with the lower compression, you can then add FI for massive hp.
Yes we all know superchargers are great but my question was N/A...
