Rear shuddering w/ wheel spacers
Old Nov 5, 2011 | 10:02 PM
aa2033's Avatar
I've searched the crap out of this topic before I made a thread, I even PMed a few people.
Didn't find too much, so I'm looking for help from the masses.
I put on 25mm Kday spacers on the front, and 31mm on the rear. I love them, they're perfect.
I had the fenders rolled for clearance, as i'm lowered on tien h techs for the 350z.
So on to my issues, at speeds over 65 mph, my steering wheel starts to shudder a little bit, it's not so bad that I HAVE to slow down, but it's certainly noticeable.
I also have shuddering from the rear wheels at those speeds. the shuddering from the wheels make me extremely nervous, so I've been going easy on the speed lately. I'm 100% sure that the shuddering is caused by the spacers as i had NOTHING like this before. I took the spacers off the rear and went driving and replicated the driving, no shuddering at all.
One of my friends suggested I might need another alignment due to the spacers pushing the wheels out and making things a little off. That makes sense to me, do you guys agree with him?
Everythings torqued down properly, and the spacers are installed properly, so I don't think it's a installation error.
So what do you guys think?
Old Nov 5, 2011 | 10:39 PM
Cox_G35's Avatar
I have the same problem. At higher speeds it gets worse. I just took mine off completely before I ruin a wheel bearing or something else.
Old Nov 5, 2011 | 10:42 PM
IIIHawKIII's Avatar
crush ring mod maybe....
i tried to find the link but i can't. and i'm in a hurry.
short version...you put some 10 or 12 ga bare copper solid core wire under where the hub goes in the middle.
Old Nov 5, 2011 | 11:35 PM
jstudrawa's Avatar
I just put some Z1 20mm spacers on today, okay okay... Daniel at Z1 did it....
But I drove back to Atlanta topping 100 at times with absolutely NO shake or anything odd.
Did you torque them enough? Are they cleanly seated? Is quality an issue with them.
I can't speak for any other spacer, and only had these a day, but they are rock solid so far.
I'd find a way to spin the spacers on a lathe or similar to see if they arent perfectly machined.
Maybe you mounted them wrong? Try again and see.
Old Nov 5, 2011 | 11:37 PM
jstudrawa's Avatar
Sorry, you said you torqued them.
If install isn't a problem, that leaves the spacers themselves.
You know what you need to do, so do it.
Old Nov 6, 2011 | 10:16 AM
Blue Dream's Avatar
I drove ttrank's car solo
Sounds like your spacers aren't hubcentric. You will need to buy hubcentric rings if they'
re not. Without them your wheel isn't seated firmly on the spacer causing the wobble or shake you are experiencing.
Old Nov 6, 2011 | 11:37 AM
aa2033's Avatar
Kdays spacers are hubcentric.
Old Nov 6, 2011 | 04:25 PM
TrixR4kidz's Avatar
I have kday spacers 30mm in the rear and 20 up front.. no issues at all even at 120+mph.. just saying from experience maybe its due to something else? Alignment?
Old Nov 6, 2011 | 04:27 PM
aa2033's Avatar
my alignment was good before i put the spacers on. my friend thought that it could be an alignment issue, but a lot of people here are saying they didn't need one.. so tomorrow i'm throwing my car back on the lift and taking the rears off. I'll clean them, make sure everything is smooth, secure, etc. And try one more time. If that doesn't do it, i'll do the alignment, if that isn't it... bah.
Old Nov 6, 2011 | 11:17 PM
G2FLIP4's Avatar
everything
Kday spacers here too... went well over 100 and never had any issues.
Old Nov 7, 2011 | 01:24 AM
wyldfyer's Avatar
Hey Boss! If you don't mind me asking... what's "Z1"? Speed shop somewhere near ATL? I NEED that in my life, LOL. Thanks, bro!
Old Nov 7, 2011 | 02:00 AM
herrschaft's Avatar
^Pretty sure he's referring to Z1 Motorsports. http://www.z1motorsports.com/350_g35...oducts_id=4215
Old Nov 7, 2011 | 01:10 PM
jstudrawa's Avatar
Correct. Great group of guys, just not IN Atlanta.
They're out west on 20 past 6 Flags. It's an hour drive for me, but very worth a day spent learning and meeting people.
Edit: I got the ones with the bolts built in, not using extended bolts.
Old Nov 7, 2011 | 01:58 PM
LoSt180's Avatar
Sounds like the spacers aren't hubcentric. Especially since you said you took them off and the wheel shakes went away.
I came across your Kday Review thread and it looks like you had some issues with those spacers from the beginning. Maybe bad batch?
Spacers shouldn't mess up your alignment either.
Old Dec 20, 2011 | 07:16 PM
CHAMUKO's Avatar
I got the same problem. U have 25mm spacers and my wheels shake.. my buddy told me that u have to torque them correctly if not they will b a lil of balance ... Havnt tried it but I will this weekend
