Is it me or do our cars idle loud as freaking heck?????
Old Nov 24, 2011 | 02:22 PM
Lone Wolf's Avatar
Originally Posted by AmateuRN
I don't know who you noobs are. I don't know what you noobs want. If you are looking for attention, I can tell you I don't have the patience. But what I do have are a very particular set of skills; skills I have acquired over a very long posting career. Skills that make me a nightmare for noobs like you. If you stop posting **** now, that'll be the end of it. I will not look for you, I will not troll you. But if you don't, I will find for you, I will troll you, and I will perma-ban you.
I see what you did there!
Old Nov 25, 2011 | 09:58 AM
grazsrootz's Avatar
Originally Posted by Jiggyfingers
I am only 3 months into owning my 07 Coupe with 72,000 miles.....
I just can't help but notice that my car at idle is one chatting loud mouth SOB. I just hear allot of chatter from both the motor and clutch. My oil is ok and always topped off. I use Synthetic oil. I do not hear knocking. Very slight ticking but that could be resonating from anywhere. On some days I hear it all the way in the rear of the motor then on other days it comes from the front of the car where the timing chain cover sits. It doesn't burn too much oil. When I did pull all the plugs they were golden tanned at the tips. Perfect burn in my opinion. The belts are good to. No squeeks. Fans seem ok. Plus the car runs really strong.
But enough of that. There are no leaks, no smoke, no surging idle, oil and all fluids are fresh and topped off. Nothing that sticks out at me except for how this car sounds. I also average 600-700 RPM during idle.
So is it just the nature of the beast?
What's your take on this?
I use Mobil 1 Synthetic.....Should I use Castrol Synthetic European Blend to quite her down a bit?
Do you have a manual trans??? i have an 07 with 50,000 miles on it. The chatter you are hearing is clutch chatter, if you have MT of course. Next time you hear it push the clutch in and notice the sound magically disappear. I just replaced my flywheel and clutch. I had a lightweight racing flywheel installed and the sound is even worse now. the 6mt is just a VERY loud and unrefined transmission, i dont mind it because if i wanted refined i would have gotten a Manual transmission. i have the ticking noise too. and my maxima with the same engine i had years ago had the ticking too. Also if you are burning oil you should look into the OC issue i they replaced my engine for free and it only has about 20000 miles on it since then.
Wayne9011
Aug 17, 2015 01:24 AM
ghost_g35
Aug 7, 2015 10:31 AM
Wayne9011
Jul 27, 2015 11:25 AM
Rehman2009
Jul 27, 2015 03:23 AM
justgotg35
Jul 19, 2015 12:33 PM
